hp 15-g charging proplem
  • menshawy
    • Aug 2013
    • 400
    • egypt
    hi friends
    i have problem with hp 15-g mb la-A996p rev 1.0
    the mb not charging the battery and don't power on with battery
    at first i found pq104 is shorted i replace it but with no change
    the mb power on with ac adapter but dont power on with battery but if i connect the battery and ac adapter it is power on and if i remove the adapter it is still powering on
    with battery
    pr110 .pl102 . pr103 is 14.56v
    any section can i check
    help please
    thanks
  • emestee
    • 228
    Re: hp 15-g charging proplem
    Start looking at the charger circuit.
    If there's 14V on PL102 it means the charger is trying to charge the battery. See sheet 37 for additional battery circuits. Note the PJPB2 jumper which bypasses the charge control circuit; you can short it to see if the battery begins charging. If it does, check the control circuit. Your primary suspects will be the mosfets around the charger, the adapter identification circuit (on HP its voltage driven) and various charger IC inputs, otherwise.
    • menshawy
      • Aug 2013
      • 400
      • egypt
      thanks for replay
      pl102 is 14.85v with battery and charger
      PJPB2 jumper already solderd
      my question is why this mb not power up from battery Even though pr103 has 14.56v
      other note : when i power on with battery and charger it is display with back light only without data but with charger only it is display ok with data
      • menshawy
        • Aug 2013
        • 400
        • egypt
        pq101 pin5 19v
        pin4 25v
        pins 1,2,3 19v
        pq103 pins 1,2,3 19v
        pin4 25v
        pin5 19v
        how to check adapter identification circuit
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • flat-earther
          how to prevent a connected charger from draining battery when not charging?
          by flat-earther
          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
          So the battery is backfeeding the charger and being drained.
          How can I prevent...
          08-07-2025, 01:04 PM
        • dimis1975
          Macbook A1466 2014 not charging with macsafe 2 charger
          by dimis1975
          I have a macboook air a1466 that stopped charging the battery.
          BAT PINS: with or without ADAPTER IN
          1- GND
          2- GND
          3- GND
          4-0V sense pin
          5-3.42V
          6-3.42V
          7- 8.4V
          8- 8.4V
          9- 8.4V
          AC Adapter plugged in: after a lot of of hours some times start charging
          No BAT Connected- Green to Orange
          AC Adapter plugged in: BAT Connected- no light
          The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
          Any ideas what’s wrong please?...
          08-05-2025, 03:43 AM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • pc_okay
          FX516PR not charging on DC charger (but charging on Type-C)
          by pc_okay
          Hello friends,
          I have this board not charging with charger, working fine on battery and type-C charger.
          Here what if found: my IC chip miss VCC so i follow the line P_CHG_VCC_30 (0V) to P_CHG_VCC_R_30 (0v) and i get 20V A/D_DOCK_IN.
          I loose my 20V on the PQ9009, i think it's dead because it's a P-Channel and I get 0V on gate and 20V on source and finally 0V on drain.
          Am I right?
          Links for shematics and boardview: https://www.badcaps.net/forum/troubl...aptops-tablets...
          10-02-2024, 06:16 AM
