Lenovo ThinkPad T530 - charging slowly and system unstable while charging
  • krtech23
    • Dec 2020
    • 7
    • Czech Republic
    Hello, I recently purchased a T530 from a seller, who used it for a couple years without battery, just with a docking station. I bought a new 6-cell battery (non-original, but a very high quality one, from a brand with almost 100% reliability).
    The laptop at first didn't want to charge with the included 90 W AC adapter while being shut down, but after powering it on it began "sipping" power. When after 5 hours the battery wasn't 100% charged, I wanted to run AIDA, but the laptop immediately powered off. I tested without battery and with just battery (and no charger), both were 100% stable. When I ran a system stability test on battery, the CPU clock speed was around 3 GHz and temps at 60 °C stable. After plugging the charger, the CPU speed dropped to under 1 GHz along with the temps, then the fan ramped up and the system crashed. The battery was > 70 % charged at that point, so it shouldn't have been just the charger disconnecting.
    I had the same results with another 90 W charger. Later I managed to borrow a used original battery from T430, but it was the same with the original 90 W charger.
    I've been doing some more diagnostics with a 65 W charger for my ThinkPad E145. In OS, the system is stable, but the charger keeps connecting and disconnecting. The battery indicator on the lid blinks like this: blink - shorter delay - blink - longer delay.
    There is an audible click coming from the motherboard while charging with the 65 W charger (only when the battery is plugged in). I removed the top cover to by able to more precisely locate the sound and it seems to be coming from the power mosfet and charger circuit area. There is no visible water damage anywhere on the board and at first glance, none of the components seem to heat up.
    Do you think replacing the charger chip would be enough?
  • emestee
    • 228
    Re: Lenovo ThinkPad T530 - charging slowly and system unstable while charging
    You should not be replacing anything before you diagnose the problem. The charger controller, the EC and the battery communicate over SMbus. If the EC believes that the battery needs to be charged but the adapter wont have enough wattage to charge the battery and sustain high performance, it will throttle down the CPU (and/or reduce the battery charging current by instructing the charger to limit it), which is consistent with what you're seeing. If you have a protocol analyzer, you can sniff out the SMBus commands and confirm that this is indeed the case. If the EC believes that the system is consuming too much current, it will shut down the board. Similarly, any of the integrated power supplies on the board may detect an emergency condition and withdraw its power good signal, which in turn will trigger EC emergency. What constitutes "too much current" again depends on how much adapter power is available and whether the battery is charging. The on/off triggering of the adapter is the charger triggering the MOSFETs, either because it detects some fault condition or because it is being told to by EC.
    The EC determines which kind of adapter it is (ie how much power is available) by reading the central pin of the adapter connector (which is pulled from 19V by a resistor) into an ADC. That is to say, the voltage on the pin determines the type of the adapter. If the ADC read-off circuit is damaged, the adapter will not be identified correctly.
    I would begin with making sure that the BIOS in the machine matches the actual model, and then seeing if the BIOS correctly identifies the adapter.
    • krtech23
      • Dec 2020
      • 7
      • Czech Republic
      Hi, thanks for your reply. I was planning on diagnosing the problem more thoroughly later (I had too little time to do it up until now).
      However, I tried to power it up yesterday and it wouldn't post. After disconnecting power and cmos battery for 30 seconds, on the first power on (from battery only) it gave me incorrect time warning, then died immediately and wouldn't post again.
      I will try to fix the bios. If there are any issues after that, I'll post another question after proper diagnostics.
      • emestee
        • 228
        I dont think the BIOS here needs fixing. If the machine is able to start, but shuts down very soon after that, you need to look for the reason it does so. This is typical for liquid damage, thermal protection, bad capacitors and so on. You need to perform basic board diagnostics, and find out how the shutdown is triggered.
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • flat-earther
          how to prevent a connected charger from draining battery when not charging?
          by flat-earther
          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
          So the battery is backfeeding the charger and being drained.
          How can I prevent...
          08-07-2025, 01:04 PM
        • dimis1975
          Macbook A1466 2014 not charging with macsafe 2 charger
          by dimis1975
          I have a macboook air a1466 that stopped charging the battery.
          BAT PINS: with or without ADAPTER IN
          1- GND
          2- GND
          3- GND
          4-0V sense pin
          5-3.42V
          6-3.42V
          7- 8.4V
          8- 8.4V
          9- 8.4V
          AC Adapter plugged in: after a lot of of hours some times start charging
          No BAT Connected- Green to Orange
          AC Adapter plugged in: BAT Connected- no light
          The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
          Any ideas what’s wrong please?...
          08-05-2025, 03:43 AM
        • pc_okay
          FX516PR not charging on DC charger (but charging on Type-C)
          by pc_okay
          Hello friends,
          I have this board not charging with charger, working fine on battery and type-C charger.
          Here what if found: my IC chip miss VCC so i follow the line P_CHG_VCC_30 (0V) to P_CHG_VCC_R_30 (0v) and i get 20V A/D_DOCK_IN.
          I loose my 20V on the PQ9009, i think it's dead because it's a P-Channel and I get 0V on gate and 20V on source and finally 0V on drain.
          Am I right?
          Links for shematics and boardview: https://www.badcaps.net/forum/troubl...aptops-tablets...
          10-02-2024, 06:16 AM
          Bauer tool battery pack charging with a HERCULES charger modification
          The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
          Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
          05-06-2023, 12:17 PM
