Apple Macbook A1398 Battery charge fail
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi guys,
    I've a problem on a Macbook A1398, motherboard code 820-3787-A.
    It didn't work, so we have changed U7100 (ISL 6259).
    Now it works, but the battery charge till about 40%, then stop the charge.
    After this, the battery start to discharge even if the power supply it's plugged.
    The motherboard doesn't work without battery, so when the battery go down to 0%, it doesn't turn on.
    The power supply it's good.
    Any suggestion?
    Thanks and best regards.
    Samuele
  • zpi
    • Feb 2018
    • 132
    • Lithuania
    Re: Apple Macbook A1398 Battery charge fail
    Disconnect battery, connect magsafe, measure ppbus_g3h.
    Also is your charger 85W ?
    • piernov
      • Jan 2016
      • 4439
      • France
      Known good battery?
      Board should work without battery with a genuine Magsafe2 85W.
      • Eleways
        • Oct 2014
        • 62
        • Italy
        Yes, my chager is 85W.
        Untill today, ppbus_g3h was 1.8V without battery and 8.5V with battery.
        Now, without battery, ppbus_g3h is 12.5V and with battery, ppbus_g3h is 12.8V.
        • zpi
          • Feb 2018
          • 132
          • Lithuania
          If it was 1.8v without battery, it did not had to charge anything. Please check if now battery is not charging. Are you sure that isl is changed correctly and all pins are on there pads? Maybe you can upload photo of isl area ?
          • Eleways
            • Oct 2014
            • 62
            • Italy
            Originally posted by piernov
            Known good battery?
            The battery is good.
            Until today the motherboard turned on only with the battery.
            Now it turns on even without the battery, but the display doesn't turn on in both cases.
            • Eleways
              • Oct 2014
              • 62
              • Italy
              Yes, I'm sure that the isl is correctly changed.
              I think that the battery is charging now but I'm not sure because the display doesn't turn on.
