Lenovo Ideapad 110-15ACL-Doesnt work from battery
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Model:Lenovo Ideapad 110-15ACL
    MB Code: NM-A841
    Problem: The laptop came with charging issue. PQ303 Was shorted and PQ308 was corroded. Both item replaced with exact same parts. Now , its charging, works fine from adapter only but doesnt gets on from battery only(Battery is perfect and tested on another lenovo laptop). However, if you connect the adapter once and remove it and then instantly if i try to turn it on-it works from battery only. After a gap of 2-3 mins, it wont work from battery again.
    I've flashed virgin bios from lenovo site but issue persists.
    PQ303-PIN 5-6-7-8 reads 11.6V on battery only
    PIN 1-2-3-11.6V on battery only, PIN4-no voltage.
    In adapter mode: Pin5-6-7-8 reads 11.6V
    Pin 1-2-3 reads 19V, pin4 reads 18.2V
    PQ308 is working correctly(schematic is wrong in this part). Pin2-3.3V,pin3-19V, rest pins 0V in ac mode, On battery only-all pins 0V.
    PR304/305/306/347-rating ok as per schematic. PD301/302 also ok.
    Battery pin volatge:
    PIN 1-2-11.6V
    PIN 3& 4-3.3V
    PIN 5-0.3V(only when adapter connected, else 0V)
    PIN 5 voltage- PR203(100K) & PR204(10K) acts as voltage divider. I do get 3.3V on one side of PR203 . So to me pin 5 voltage at 0.3V seems ok.
    What could be wrong here??
    I've replaced charging IC OZ8682 also(NEW)-same problem persist.
    PS: I tried but couldnt flash ITE8586 as svod2 gives error-cant detect ite series.
  • emestee
    • 228
    Re: Lenovo Ideapad 110-15ACL-Doesnt work from battery
    There's a power plane state table in the schematics. I would start by verifying that the voltages that are supposed to be present when the battery is plugged in are actually present (in particular V3ALW which goes to the EC)
    • piernov
      • Jan 2016
      • 4439
      • France
      Battery percentage reported properly?
      +3VALW won't be present on battery only before pressing power button. After pressing power button it should come up. +3VL should always be present.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        +3VL is present.
        Battery percent is reported correctly.
        • SONIAM
          • Mar 2021
          • PORTUGAL
          HI, Where I can buy PQ308?
          • ferah831208
            by ferah831208
            03-18-2025, 01:18 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • jared101
            Lenovo Ideapad 320-15IKA NM-B452 not charging battery
            by jared101
            NM-B452
            Hi guys. I've used the forum a lot but never asked questions before. I had a Lenovo come in that was shorted on the 20V rail. I fixed that and thought my job was done until I realized it wasn't charging the battery. Here is what I've checked so far
            On the BQ24780SRUYR charging ic
            VCC 20V
            SMBUS lines
            SDA 3.3V
            SCL 3.3V
            Current Sensing lines
            ACP/ACN 2.3 ohms
            SRP/SRN 21.2 ohms
            REGEN line 6V
            PHASE .84V with no battery installed(this may be normal)
            08-03-2022, 09:19 PM
          • ahmarzo
            Lenovo IdeaPad 330s no display on battery
            by ahmarzo
            Have lenovo IdeaPad 330s with motherboard part no 330s_kbl_v09.the laptop works fine on adapter and the battery charges fine .but when powered through battery power stays for 1-2 seconds and shutdown.have changed the charging ic and bq24780s and tried another working battery
            When power button is pressed on battery 3v and 5 v comes and goes and all voltages are present for 1-2 seconds.
            Help me solve this problem here is the link for schematic https://www.badcaps.net/filedata/fetch?id=3230319.
            02-13-2025, 10:26 AM
          • code share
            Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
            by code share
            I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
            Here's what I've tried so far:
            • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
            • Booted successfully on AC power only with the battery disconnected
            • Visual inspection of the battery — no swelling, burn marks, or connector damage
            • Battery
            04-21-2025, 12:50 PM
