Asus x555LD after flash bios starting too long and cannot enter windows
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello.
    have this Asus x555LD that after flash bios, it is starting too long before show logo and cannot enter windows, even with installation usb it freeze after some reading
    original bios make it hard shutdown after few seconds even after intel ME replace
    flashed many bioses, but every have long start and cannot start win install
    board have mark x555ld and have intel i3-4020U and Nvidia gt840m gpu
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Asus x555LD after flash bios starting too long and cannot enter windows
    Make sure you cleaned ME region properly on a working dump. Send your dumps and ask for clean BIOS with clean ME in BIOS request section.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      fix three bios all work ok, but when come to loading system, it freeze
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        i think your i/o chip is not working properly
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          No. Even after change ITE nothing changed
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            Hi , It is a ME region clean issue(20 second display delay) as advised by senior member , Post your Bios ME region clean request in " BIOS SECTION ONLY"
            clean ME region Bios will solve this issue (version mismatch issue) and your laptop will show display faster.
            You can check this issue reported in many sections in Dr.BioS
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              i cleaned ME and logo goes normal, but i have problem with windows start
                • 21874
                The 50 pin HDD connectors are a known problem on these boards .Did you make the USB bootable MBR or GPT
                https://www.aliexpress.com/i/33024147419.html
                https://www.youtube.com/watch?v=L0mm282rkNs
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3627
                  • slovakia
                  It freeze even with usb installation. ubuntu give me page fault error. I think that that onboard ram may be problem.
                  Have anybody proved RAM disable on this board?
                  X555LD rev. 2.0
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    X555LD rev. 2.0
                    proved RAM disable, check for your MB
                    https://www.badcaps.net/forum/showthread.php?t=61655
                    • BMCappelletti
                      Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                      by BMCappelletti
                      Hi everyone.
                      Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                      Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                      Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                      02-18-2025, 12:22 PM
                    • alfredposadas09
                      cant enter recovery mode lenovo c13 yoga chromebook
                      by alfredposadas09
                      cant enter recovery mode lenovo c13 yoga chromebook try esc+refresh+power at first scenario i was able to enter recovery mode but it was failing to reinstall os .. i try to change ssd and when i try this i cant enter recovery mode now...
                      11-09-2024, 10:09 AM
                    • tranquility
                      Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                      by tranquility
                      i want to repair an Onkyo TX-NR809 receiver.
                      symptoms:
                      on power on, display appears and i hear one click. enue functions is given.
                      - no hdmi output
                      - audio output not tested, but i think it is not there
                      - usb sticks are not recognized
                      if i read out the chips with display+standby button + tone+
                      both dts show only ????
                      chip is D830K013BZKB4
                      things i have done:
                      - reflow of the dts chip without taking off and reballing
                      - changed the aluminium caps without the big one with 25v because i dont...
                      08-25-2025, 01:04 AM
                    • Online_internet
                      Windows re-activation problem
                      by Online_internet
                      I have a problem with windows activation. The laptop has the original version of windows 8 included by the manufacturer. The laptop worked on the original activated key for several years. Recently I wanted to try to see if I could still upgrade to windows 10 (it was a mistake). Of course, the time to upgrade to windows 10 has long since ended and my key was rejected. I came to terms with this and wanted to reinstall windows 8, I downloaded the system from the windows website, after starting the procedure it showed a window to enter the key, I entered and to my surprise now also...
                      04-30-2024, 09:49 AM
                    • angeloavv
                      ASRock H81M-DG4 power cycles and glitches - sometimes POSTs sometimes not
                      by angeloavv
                      Hello everyone! This is my first post and this motherboard is driving me crazy because everything looks so non-trivial that I don't know where to start investigating. During these days I believe I watched half of the YouTube videos trying to understand how to troubleshoot power cycles but at the same time, I'm confused because my motherboard doesn't always do that and sometimes completes the POST for a few seconds: the right amount of time to freeze, show glitches on the screen, and then reset itself.
                      Let me give you a bit more context to understand why and how we got here.
                      12-26-2023, 03:32 PM
