Acer 8920g problem
  • Rikintosh
    • Oct 2020
    • 5
    • Brasil
    Acer 8920g problem
    I recently purchased a defective Acer 8920G. I bought it, because years ago I bought an acer 6920g and managed to fix it at home, exchanging the nec tokin for 4x330uf caps.
    However, to my surprise, when I took it apart, I saw that it was already without the nec tokin. Someone replaced it with 4x330uf .
    The problem is, it doesn't show an image on the screen! There is no problem with inverter, it will not show video on the external monitor, hdmi, vga, svideo etc ... It turns on, turns the fan, turns on the illuminated panel on the left, but then it turns off suddenly, then turns on again, and stays permanently on without showing any image.
    - already tested with other video cards
    - already tested with other memories
    - already tested with another flat and display
    - already tested with another processor
    I'm thinking of changing the capacitors again, but I didn't want to waste time, so I'm creating this post, maybe someone has already been through this and can help me, before I start destroying this motherboard lol
    Just out of curiosity, I bought a 8930g, with a very similar problem, however, when connecting the charger, it turns on itself, and remains on without showing an image on the screen. He was also exchanged nec tokin (for someone else), but from what I read on this forum he requires 470uf capacitors, but in fact they put 4x330uf + 2x220uf capacitors on him.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Acer 8920g problem
    Post pictures of what the replacement capacitors look like.
    These machines had a defective NVidia GPU, if it doesn't have white underfill it's most likely bad, make sure you try with a good compatible graphics card.
    • Rikintosh
      • Oct 2020
      • 5
      • Brasil
      Yes, I've tested it with other 9500gt, 9600gt video cards, from other acer notebooks. No luck.
      Images:
      8920G:
      8930G
      • Michiel
        • Oct 2015
        • 32
        • Netherlands
        Hi there, Did you manage to solve the problem like in the first post ?
        I have 2 the same Acers here (the 8920g with ddr2) and a 8930g, ddr3 both not showing picture.
        When it does power on itself it is just the CMOS battery empty, like most acers does.
        about the acer 8920g not showing picture / not posting
        I readed that the CPU core needs to be 1 volt + or higher.
        I measure only 0.90 volts on the CPU ( and nec tokin)
        Nec tokin is replaced for 4x330uF smd.
        Do you know why the CPU is on low power ?
        PowerGood singal is 3.3volts everywhere.
        and replaced the bios.
        I checked the CPU power IC and VSSSENSE seems to be shorted to ground ?? is that normal ?
        • piernov
          • Jan 2016
          • 4435
          • France
          Post picture of NEC Tokin replacement.
          VSSSENSE is connected to ground.
          • Michiel
            • Oct 2015
            • 32
            • Netherlands
            pictures
            • Sephir0th
              • Oct 2020
              • 1262
              Maybe i'm wrong but this doesn't Looks Like a proper replacement of an NEC Tokin, when i compare e.g. with the attached Pic...
              However i never did It so far...
              FairRepair on YouTube
              • Sametbey
                • Jan 2021
                • 229
                • Turkey
                if you look at it from this angle. it shouldn't be a problem theoretically. He used 330ufs long. North should work on chip.
                I'm not happy to be so strong. because it's not humanly
                • Sephir0th
                  • Oct 2020
                  • 1262
                  Ah, i See. So Maybe there has to be done some measurements around the PWM-Controller for VCore etc. Thanks for clarifying.
                  • Michiel
                    • Oct 2015
                    • 32
                    • Netherlands
                    thanks, it's the 4th acer now which I have done the NEC tokin repair. The first was done not so well hehehe :-(
                    but they still work. this one doesn't
                    I tried a third processor, a Celeron now and this one goes up to 1.15 volts and getting pretty hot
                    so I don't think the problem is in the vcore voltage.
                    also tried 3 other videocards, 1 seems broken because the screen goes to full black immediately when pressing power. tried different rams etc etc
                    I set the bios back to the original bin, but no luck
                    all voltages are there
                    can it be a broken Northbridge ? a USB drive is not reading when plugged in
                    it goes on, 5 seconds later off...and then stays on
                    maybe I can bypass something ?
                    • Ludmilaharhordina
                      ACER A315-53G C5V01 LA-E892P rev2A the laptop turns on, but the display does not show
                      by Ludmilaharhordina
                      good afternoon.
                      need help.
                      the laptop turns on, but the display does not show.
                      the laptop came to me from another workshop. visually broken USB 3.0 and soldered BIOS flash drive.
                      I unsoldered USB 3.0 and flashed several different BIOSes, but it did not help.
                      +VCC_CORE 0V
                      +VCC_GT 0V
                      +VCC_SA 1.03V
                      +0.6VS_VTT 0.6V
                      +1.0VALW_PRIM 1.0V
                      +1.0V.VCCSTU 1.0V
                      +VCCIO 1.OV
                      +1.0VS_VCCSTG 1.0V
                      +1.2V_VDDQ 1.21V
                      +1.8VALW_PRIM 1.81V
                      +1.8VS 1.81V
                      +3VLP 3.27V
                      +3VALW...
                      04-02-2025, 08:51 AM
                      09-06-2024, 05:27 AM
                    • Victor Moreira Silva
                      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                      by Victor Moreira Silva
                      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                      Well, my decice specs are the following:
                      Model: Acer Nitro 5 AN517-54-55T5
                      CPU: Intel Core i5-11400H
                      GPU: NVIDIA GeForce GTX 1650
                      Motherboard: GH51G LA-L181P Rev:1c
                      The symptom:
                      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                      05-26-2025, 10:49 AM
                      Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                      This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                      09-07-2024, 05:00 AM
                      Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                      This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
