820-2132-A, A1229 blinking light on magsafe
    Re: 820-2132-A, A1229 blinking light on magsafe
    Originally posted by lcdcaps1 View Post
    I have tested the s0 rails for ohms
    and they are below
    PP5V_S0 2.245k ohm
    PPVCORE_S0_CPU 0.5 ohm
    PPVCORE_S0_NB_GFX 42.1 ohm
    PP3V3_S0 0.7k ohm
    PP1V8_S0 1.3k ohm
    PP1V5_S0 462 ohm
    PP1V25_S0 130 ohm
    PP1V05_S0 26.3 ohm
    PPVCORE_S0_NB_R 26.1 ohm
    PP0V9_S0 1.4k ohm
    Hi can someone help me please
    I don't know if the following is a real short or if it is meant to be so low
    On this model the cpu is T7800
    I put one multimeter leads on ground and other on pin 2 on the coil and get the following
    L7100 is 0.5 ohm
    L7101 is also 0.5 ohm
    Does this mean My cpu is dead
      Yes that's a short to ground, it should be at least a few ohms.
      I've never seen a Core 2 Duo CPU get internally shorted though.
        what could be causing the short
        do i remove L7100 and L7101
          I was looking on the board view
          L7100 pin 1 goes to IMVP6_PHASE1 and Pin 2 goes to PPVCORE_S0_CPU
          I then looked at all the points it connects to regarding PPVCORE_S0_CPU
          I saw that it connects to R1100
          R1100 is 100 ohms but i measured mine and it is 000.4 ohms
          could this be bringing the ohm reading down on L7100
            CPU_VCCSENSE_P is connected to PPVCORE_S0_CPU inside the CPU, so it's normal to measure 0 ohm between CPU_VCCSENSE_P and PPVCORE_S0_CPU.
              Hi
              do i have a short on L7100 and L7101
                Hi all
                Can My CPU be bad or can U7100 be bad
                Please will really appreciate the help from everyone
                Many Thanks
                  Any components connected to both PPVCORE_S0_CPU and ground could be bad, including the CPU, the low-side MOSFETs of the buck converter, the buck controller the bypass capacitors, …
                    Hi what would be the quickest way to find out whats causing this
                    voltage injection could be risky, right ?
                      If you don't go above 1.3V it's fine.
                        What about amps
                        Where should I connect My positive wire
                        on the coil ?
                        Also should I remove the coils before doing this
                          Hi all
                            Hi, has anyone worked on this motherboard model before
                            Please
                              on another board
                              R1100 measures normal
                                what cpu it has ? on all macbook with core duo on inductor cpu i have from 015 to 034 in diode mode values, so if u have 004 i think there is some problem with cpu itself.
                                try remove both cpu inductor and see wich side u have low value... if its cpu side maybe there is a problem with cpu.
                                  Hi
                                  Thanks for the reply
                                  The cpu is T7800
                                  I have lifted the coils
                                  L7100 and L7101
                                  The short to ground is on the cpu side
                                  On L7100 pin 1 is 3.9k ohms and pin 2 is 0.5 ohms
                                  on L7101 pin 1 is9k 9.4k ohms and pin 2 is 0.7 ohms
                                    Hi
                                    I have an adjustable power supply (MAISHENG MS3010D) and trying to get the voltage injection to work
                                    I have lifted the coils to isolate the cpu
                                    I set voltage to 0.30v but when i short the leads i cannot get it to do current limiting
                                    so the c.c light does not light but the current shows 0.10A
                                    Can someone help me with this
                                    Many Thanks
                                    i connect positive lead to PPVCORE_S0_CPU and other lead to ground
                                      Increase voltage to 1.2V. With 0.7 ohms to ground that should generate 1.7A of current and 2W of heat.
                                        I cant see any sign of damaged component
