TOSHIBA C55- B861 no data on screen
  • nabilgo
    • May 2016
    • 303
    • L.A
    hey i have toshiba TOSHIBA C55- B861 borad numb DA0BLJMB6C0 REV C
    the probleme when i turn on it work good on external screnn but the inside screen only get backlight but no data
    LVDS PIN 30 PIN: pin 1 and 2 i found 19v pin 4 and 5 got 3.3 pin 6 3.3 v pin 7 no voltage pin 8 no voltage pin 11 0.09 pin 12 0.12
  • peste
    • Dec 2016
    • 13600
    • ROMANIA
    Re: TOSHIBA C55- B861 no data on screen
    try another display.
    • nabilgo
      • May 2016
      • 303
      • L.A
      i did try new display and new screen cable
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
        09-06-2024, 05:27 AM
      • sigmeyer
        Toshiba 50UL4B63DG faulty screen?
        by sigmeyer
        I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
        08-30-2025, 08:13 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
        09-06-2024, 05:59 AM
