Acer E1-532 LA-9532P wont work without charged battery
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3586
    • slovakia
    Hello.
    HAve this Acer E1-532 LA-9532P that wont work without charged battery. if battery and power removed and attach power, forst two mosfet not work. if attach discharged battery its the same story.
    when i short first mosfet for second with attached battery everything work, like when i connect charged battery
    its the third laptop with same symptoms. have somebody clue why it behave like this?
    charger ic is BQ24735
    attached readings
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: Acer E1-532 LA-9532P wont work without charged battery
    check resistor of first mosfet if they are ok and what voltage they have.
    post voltage on : pq302, pq303, pr303, pq304, pq305
    measure volts with charger only, and with battery and charger .
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      PQ101/PU102 Working checked?? 51ON# circuit probed??
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3586
        • slovakia
        none of them are on board
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3586
          • slovakia
          WITHOUT BATTERY:
          pq302: 123-short pulses up to 5V
          4 - short pulses up to 5V
          5678 - 19.5V
          pq303: 123 - short pulses up to 5V
          5678 - 2.5V with short pulses to 5V
          pr303: 2.5V with short pulses to 5V
          pq304: 5 - 2.5V with short pulses to 5V
          4 - 2.5V with short pulses to 5V
          123 - 2.5V
          pq305 - same as pq304
          WITH CHARGED BATTERY:
          pq302: 123- 20V
          4 - 26V
          5678 - 20V
          pq303: 123 - 20V
          4 - 26.6V
          5678 - 20V
          pr303: 20V both side
          pq304: 5 - 20V
          4 - 16.8V
          123 - 16.8V
          pq305 - 123- 16.76V
          4- - 21V
          5 - 20V
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            remove pr303 and measure pq302 with charger only.
            then remove also pq303 and check pq303 voltage with charger only.
            battery nominal voltage ?
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3586
              • slovakia
              Without PR303 all works normal even without battery
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                with all works normal what do you mean ? pq302 volt is 19 , 5 and 19 output ?
                is so put back pr303, remove pq304 and post result
                edit: before removing pq304, read voltage pins. then remove and read again voltage pins of pq304
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3586
                  • slovakia
                  without it have same measures like without battery
                  without pr303 i have 20V on its pad
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    i write not perfect. without pr303 and without battery u have 20volt on pr303 first pad?
                    if so put back pr303 and remove pq304. stil l20 volt on pr303 charger only ?
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3586
                      • slovakia
                      "without pr303 and without battery u have 20volt on pr303 first pad?" - YES
                      if so put back pr303 and remove pq304. stil l20 volt on pr303 charger only ? - NO
                      • dellxps15
                        • Feb 2014
                        • 1588
                        • italy
                        remove pq305 and put back pq304... without battery u have 20 volt on pr303 ?
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3586
                          • slovakia
                          without charged battery i have 2.5V on pr303
                          without battery and pr303 i have 20V on its pad
                          • dellxps15
                            • Feb 2014
                            • 1588
                            • italy
                            that lead to me to a bad pq305.... (if u put back all component except pq305) and u have volts on pr303.
                            without pq305 try powering on the laptop. it should work without battery.
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3586
                              • slovakia
                              pq305 cannot be bad when normally charging
                              • dellxps15
                                • Feb 2014
                                • 1588
                                • italy
                                monitor pu301 pin 11 voltage with psu only, with low charge battery and with full battery
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3586
                                  • slovakia
                                  it is in pq304 measurements
                                  • dellxps15
                                    • Feb 2014
                                    • 1588
                                    • italy
                                    edit: sorry didnt remember first post.
                                    pr316 resistor value ?
                                    also pr307, pr308, pr304
                                    pc301, pc302,
                                    i suspect one of these
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3586
                                      • slovakia
                                      now for me it is looks like battery must be attached, but not flat dischaged. i discharged battery, leave it out for a day and when i attach charger it work normally
                                      • dellxps15
                                        • Feb 2014
                                        • 1588
                                        • italy
                                        it should work without battery. ive read the datasheet of BQ24735RGRR and on first picture on #1 post we have:
                                        vcc in is 19 volt, , so pd302 works.
                                        acdet is 2.65 volt.... it's in range between 2.4 and 3.15 volt so it is ok as vin+ [r2/ (r1+r2) ] = 19.7*[64.9/(422+64.9)]= 2.62...
                                        acok 0volt, so something is not happy with the carger circuit
                                        acdrv should be over 6 volt..... i suppose it to be 8-9 volt.
                                        would be curious why without battery and withour pr303 mosfet are turned on. i would like to inspect with that, pu301 voltagepin without battery and withour pr303 ?. also maybe ec need to be reprogrammed ?
                                        acok is generated by VLP i would also inspect with this.... some value is not happy here
                                        about vlp, check r494 and r495.... pu301 is told to set ac on with: +3vlp when on battery and +3valws with ac only.
                                        check also r24 and r236 (0805 0m resistor near ec.)
                                        with psu only check if 3.3 rail is working
                                        edit: is rtc battery fully charged ?
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Aspire A315-58-38H7 + Pack Gold Acer 15.6'' Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A315-58-38H7 + Pack Gold Acer 15.6'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-58-38H7 + Pack Gold Acer 15.6'' boardview and A315-58-38H7 + Pack Gold Acer 15.6'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 03:10 AM
