ACER E1-410 all usb ports not working
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I have this acer e1-410 that all usb ports not working board id 13233-1M 48.40C10.01M. I checked U6301 chip pin2 IN#2 AND PIN3 IN#3 =5V but pin 4 EN=0V PIN 6-8 OUT has also 0v. already tried replacing the chip but still no enable and output of 5v. cAN anyone please help on this
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: ACER E1-410 all usb ports not working
    anyone can help on this please
    • classicandy
      • Apr 2018
      • 308
      • Nigeria
      post its schematic diagram here
      • lapfix
        • Mar 2020
        • 2722
        • my workshop
        Without enable signale the ic don't work.
        So check EN power rail for short or a bad component
        • String2016
          • Nov 2015
          • 2238
          • philippines
          Same with U3401 pin 4 enable no 5v also , i cannot find any components connected on this @lapfix please help attached is the schematic
          • Dumah Brazorf
            • Jun 2013
            • 179
            • Italy
            Just follow the usb_pwr_en signal (use the search function) and you'll see the signal comes from the superIO chip (nuvoton NPCE781LA0DX-GP).
            So the superIO chip is bad or simply frozen. Have you tryed to reset the bios removing all sources of power? external power, main battery and cmos battery.
            EDIT: I see then usb_pwr_en line is active low so 0V enables the chips. If they don't output power and you have changed one you should check the output line for short.
            • String2016
              • Nov 2015
              • 2238
              • philippines
              thanks Dumah ill replaced all the chip and resetting cmos but now its working fine thank you
              • DynaxSC
                GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                by DynaxSC
                I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                The board is generally working now, all PCIe ports are working, Windows installs normally.
                However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                03-10-2025, 12:27 PM
                09-06-2024, 05:27 AM
                Acer Aspire A515-52-57UF Notebook 5 Specification for Upgrade or Repair
                This specification for the Acer Aspire A515-52-57UF Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-52-57UF boardview and A515-52-57UF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 07:29 AM
                Acer Swift SF315-52-86MP Notebook 3 Specification for Upgrade or Repair
                This specification for the Acer Swift SF315-52-86MP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF315-52-86MP boardview and SF315-52-86MP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 06:34 AM
                Acer Aspire Acer Aspire 5 A515-45 15.6 inch Laptop (AMD Ryzen 5 5500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                This specification for the Acer Aspire Acer Aspire 5 A515-45 15.6 inch Laptop (AMD Ryzen 5 5500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 5 A515-45 15.6 inch Laptop (AMD Ryzen 5 5500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Black) boardview and Acer Aspire 5 A515-45 15.6 inch Laptop (AMD Ryzen 5 5500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Black) schematic. Our users have donated over 1 million...
                09-07-2024, 03:10 AM
