G6-1169ea (R18D) low +VCORE
  • barry101
    Apple 820-3662 VCore shorted to ground.
    by barry101
    Hi, Would appreciate some help.
    I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
    Get charger light but no fan spin or chime. No liquid damage.
    Found PPBUS and VCORE both shorted to ground. Other rails were ok.
    Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
    With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
    Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
    06-24-2025, 07:34 AM
  • Francisco.s
    CPU vcore missing in HP workstation Z2 Mini 4G
    by Francisco.s
    Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
    The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
    It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
    Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
    The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
    I wonder which circuit generates this enable...
    04-22-2024, 12:35 PM
  • mikzs
    Rx580 8gb sapphire nitro+ turn off vcore randomly
    by mikzs
    Hello, this is my first post, English is not my native language but I hope you understand me. I recently got a 580 that didn't turn on the typical short mosfet, as I didn't know exactly which one was short, I unsoldered them until I got the bad one out, I was able to remove the short and identify the bad mosfet, the gpu gives video again! but it has a problem that completely turns off vcore at random times or if I try to put a load on the gpu vcore drops to 0 I don't have much idea why because I don't know much about sapphire, any advice on where I could start looking or what problem it could...
    11-06-2023, 12:28 PM
  • jm942
    Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
    by jm942
    My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
    I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
    I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
    I did voltage injection on the cpu with 0.7V and i have a current...
    07-11-2024, 05:11 AM
  • pavithra_uk
    Optiplex 3050 Vcore Mosfet short
    by pavithra_uk
    it is 3+2 vrm
    vcore high side mosfet (AON6380) shorted when turned on instatly killed the processor (i5 7400)
    gate drive chip (NCP81166) also gone.
    any suggestions before replace mosfet and gate drive chip? what if I replace 3 high side mosfets with more current capable mosfets?
    odd question:
    what if I put two silicone diodes series in forward way? assume each diode 0.7v drop and total of 1.4V. vcore not exceed this but can protect cpu from direct 12V hit from shorted mosfet ?...
    10-21-2025, 11:32 AM
