Hp 650 g1 6050a2566301-mb-a04 no display
  • sureshbobby
    • Mar 2015
    • 137
    • India
    Hi Techies Need help
    i have hp 640g1 & 650G1 laptops with the same board.
    both have same issue. when i turn on no display fan runs at high speed. flashed bios not solved.
    Actually 650g1 is working one, where i removed the cmos battery it is also behaving like that no display fan runs on high speed.
    Any Help would be appreciated.
    Thank you
  • sureshbobby
    • Mar 2015
    • 137
    • India
    Re: Hp 650 g1 6050a2566301-mb-a04 no display
    No body is there to help or dont know this type of problem.
    its very urgent guys. two laptops are with the same. need your help
    • lapfix
      • Mar 2020
      • 2765
      • my workshop
      Post your dump here : https://www.badcaps.net/forum/forumdisplay.php?f=40
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        flash bios with original bios dump version.. then if it still not working try flash it with updated version
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          Hi i would try to clear me region of the original bins, does the capslock blinks?
          • sureshbobby
            • Mar 2015
            • 137
            • India
            Hi friends thanks for the reply. i just unplugged the cmos battery and thats it. no display.
            am attaching the original dump in the bios section please help
            • sureshbobby
              • Mar 2015
              • 137
              • India
              yes caps lock blinks 3 times
              • Duranitron
                • Jul 2014
                • 544
                • Philippines
                have you checked the voltage of the cmos battery and vcc pin of the bios ic?
                • Duranitron
                  • Jul 2014
                  • 544
                  • Philippines
                  check all the power rail.. all the ALW voltage and post it here..
                  • hamada2h
                    • Nov 2018
                    • 7
                    • egypt
                    help me
                    caps lock blinks 5 times
                    • mon2
                      • 14677
                      See:
                      https://h30434.www3.hp.com/t5/Notebo...p/td-p/6703671
                      Try:
                      I just had the same issue, so I powered it off and then I pressed the power button and held it pressed for approximately 30s, then the laptop could boot fine again.
