Lenovo Flex 6 14ARR just died
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    My Lenovo 6 16 just DIED before I had to show a customer of mine a program for him. First no screen, then no power.
    Already did a cmos reset button for 30 secs while ac/batter disconnected, disconnecting everything but the power switch ffc,
    took ssd and ram out (we're taking about dead, no power, no NOTHING). I loved this thing, even though it had sleep issues-turns out that is a common issue for this one).
    This is what i'm going for next (until at least they get the 512GB ssd in neweggs stock, cause the third party seller has the 512gb more expensive than the 1tb)
    https://www.newegg.com/grey-with-blu...82E16834155448
    never used the old one except for light gaming (only can do so much with a Vega 8 on a 2500U). barely even fallout 3. Probably will not use it much for gaming. Though I doubt I can use the onboard CPU instead of the GPU for windows to save power. I don't think Nvidia Optimus exists anymore
    I just read that thing does NVME with two pci-e channels instead of the usual four
    still trying to find money for it
    People say I should go for ryzen 4000 series but there aren't many
  • diif
    • Feb 2014
    • 6978
    • England
    Re: My Lenovo 6 16 just DIED
    So no attempt at repair, with nothing to lose but a bit of time ?
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      aside from testing the fuse (which was fine), I don't have much experience with board-level repair of laptop boards, especially ones of this miniature build.
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        Can you poke around random (regulated) power points on the board (with a 'scope) while trying to turn it on? I.e., to see if it is TRYING to come up (and quitting) vs. "just plain dead"? Fans, disk, indicators... anything that might "blip"...
        You can also try removing anything that is socketed in the hope that it will COMPLAIN.
        • diif
          • Feb 2014
          • 6978
          • England
          Experience has to start somewhere, get out the screwdrivers and get it open.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            awww you edited my title. hah, yeah I get it
            as I said I opened it. took ffc's off one by one (incl screen). did he UEFI and cmos clear.
            at first the power came on but no screen. Had to keep the power button down to turn it off, this happened about three times. Then no power at all, no fans, no lights (except the charge light, which I hooked the battery up while it was plugged in and the charge light went orange to white, means it's detecting the battery level just fine). Another possibility that I thought of was hall switch but that wouldn't explain the no-screen before total power death. This is a 2-in-1 touchscreen and getting inside the monitor where the hall switch is, is such a bitch
              • 21852
              Whats the exact model number,i can`t find a Lenovo 6 16 .
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                sorry, Flex 6 14ARR.
                  • 21852
                  Here`s a link to the schematic. Can you measure the voltage on all the large square grey coils.
                  https://www.badcaps.net/forum/showthread.php?p=973992
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    Re: Lenovo Flex 6 14ARR just died
                    the ones next to the fets? and what looks like diodes? They all read 0 (with adapter plugged in)
                    all diodes read 0 except one away from the group around the fets
                      • 21852
                      check these, also can you post a few pictures of the DC in area ,both sides of the board, peel back the black plastic sheet beforehand.
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        Back of it dosen't have much. Only a few smds. Mostly blank
                          • 21852
                          Test voltage on PQ201 pins 1/4/5 ,PQ202 pins 1/4/5 ,see page 42 on the schematic.PU201 on pins 1/2/5/6/7/27. PL401/PL402 and PU1901 pins 3/6 .
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            ok, i've never dealt with fets or voltage controllers before. Is pin 1 the one with the square on the silkscreen?
                            by 1/4/5 do you mean 1&4, 1&5? 4&5?
                            401 and 402 are coils i've already tested
                            umm, let me add info. You see the M.2 slot (where the PQ201, PQ202, UH1 are?)
                            Well it's M.2 2242, which is hard to find good ones, so I got a 2280 and used a small 3M VHB strip to keep it down, looks around where PQ 201 and 202 are. I'm guessing, my dumbass insulated fets, and the heat caused them to die?
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              flea can you confirm my stupidity regarding putting high bond over those fets?
                              and help me figure out which ones to test?
                                Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                09-07-2024, 07:20 AM
                                09-07-2024, 06:38 AM
