Asus FX505DT
  • Lukosiukas
    • Jul 2018
    • 106
    • Lithuania
    Asus FX505DT
    Hello, i need to identify a component. Computer do not turn on, this is getting extremely hot. No schematics or board-view available.
    Markings on chip is :
    W27
    8
  • Lukosiukas
    • Jul 2018
    • 106
    • Lithuania
    Re: Asus FX505DT
    up, i dont want to pay 600euros for new motherboard
    • xweb
      • Aug 2011
      • 7
      Re: Asus FX505DT
      same problem here... did you solve?
      • reformatt
        • Feb 2020
        • 1443
        Re: Asus FX505DT
        I've just had one of these boards machines come through. The power adaptor immediately shuts down when connected.
        Located the fault with voltage injection and thermal camera. The area in question by the OP is for CPU Vcore, and in my case was the AOE6932 dual FET to the left. Only one of the internal FET's had shorted, the other was ok. I usually find a dead CPU at the end of this scenario. The CPU measured a little over 1.2 ohms so I was not confident. But at least it wasn't a dead short. I didn't have a replacement at the time, so I took it off the board and saw what the other phase would do. Surprisingly I got 1V. Machine wouldn't fully start because of the missing phase, but there was hope.
        So ordered it, and finally fitted the replacement AOE6932 today and machine is working fine. I have to assume the FET that shorted was the low side FET, not the high side as the CPU survived. I took the liberty to measure some volts on the coils for future reference. A little over 1 ohm seemed a little too low fpr Vcore, but there you go.
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          Re: Asus FX505DT
          Thanks,
          Is there any hot Mosfet now after the replacement?
          How much hot is the CPU now?
          • trepachka
            • Oct 2022
            • 439
            Re: Asus FX505DT
            Hello, my motherboard is also Asus FX505DT. However, the boardview I have is for a different revision of this motherboard. I need help identifying both capacitors that are not part of the boardview I have and also appear to be shorted. There are several faults with this motherboard. I removed the super I/O chip and that short is gone. However, these two capacitors are also shorted. I am afraid the GPU is dead as result. Thanks in advance.
            • Stevedb
              Stevedb
              • Feb 2018
              • 624
              • Belgium
              Re: Asus FX505DT
              How much resistance do you have. It is normal to have low resistance there it can be 1 ohm or so on newer gpu core
              • Bonzas
                • 472
                • Indonesia
                Re: Asus FX505DT
                Maybe this
                • Stevedb
                  Stevedb
                  • Feb 2018
                  • 624
                  • Belgium
                  Re: Asus FX505DT
                  I think it is jut low resistance and not a short.how much resistance do tou have to ground?
                  • trepachka
                    • Oct 2022
                    • 439
                    Re: Asus FX505DT
                    I am new to this and took the beep coming from my multimeter as a short. The resistance measures 3.2 Ohms. I am also attaching the image from the backside of either GPU or CPU (I am not sure which is which). Most of those capacitors also read about 3 ohms.
                    I definitely removed the short when I took out the super I/O chip IT8987E/BX.
                    A question: does this chip require reprogramming or can I just purchase one on eBay or any other place as long as the markings on the chip match?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Re: Asus FX505DT
                      Yes, IT8987E is programmable but with asus it'll program itself on 1st boot. Make sure the suffix after IT8987E matches.
                      • trepachka
                        • Oct 2022
                        • 439
                        Re: Asus FX505DT
                        What about the resistance value on those capacitors I had mentioned? Is it expected for the resistance to be around 3 ohms? All mosfets I checked are OK. The main power rail is present but that's about it. No other voltage is there. That's why I tested the capacitors around the controller chip and they were all shorted to ground. I am ordering a new controller chip. I am hoping that was the problem.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Re: Asus FX505DT
                          Hey man, dont mess with those caps. These are low voltage rails and caps here could show as low as 1-2 ohms and that cant be considered short.
                          • trepachka
                            • Oct 2022
                            • 439
                            Re: Asus FX505DT
                            After replacing IT8987E, I also found another fault with bq24780S chip. It was replaced as well and now I get 5v, 3.3v and 1.8v power rails. However, on power up, computer keyboard flashes keys non-stop and the notebook is not charging. Checking battery charging pin I only get 2.5v vs. 10v+ expected.
                            I am just wondering what my next step should be.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Re: Asus FX505DT
                              Locate the 2 dc-in mosfets and then measure voltage on pin1-4-8 of these fets and report back. Also mention the voltage on all pins of battery connector(without battery )
                                ASUS TUF Gaming FX505DT-HN766T Notebook Specification for Upgrade or Repair
                                This specification for the ASUS TUF Gaming FX505DT-HN766T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN766T boardview and FX505DT-HN766T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                09-07-2024, 12:10 AM
                                ASUS TUF Gaming FX505DT-HN536T Notebook Specification for Upgrade or Repair
                                This specification for the ASUS TUF Gaming FX505DT-HN536T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN536T boardview and FX505DT-HN536T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                09-06-2024, 10:50 PM
                                ASUS TUF Gaming FX505DT-HN630T Notebook Specification for Upgrade or Repair
                                This specification for the ASUS TUF Gaming FX505DT-HN630T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN630T boardview and FX505DT-HN630T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                ASUS TUF Gaming FX505DT-HN450 Notebook Specification for Upgrade or Repair
                                This specification for the ASUS TUF Gaming FX505DT-HN450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN450 boardview and FX505DT-HN450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 10:00 PM
                                ASUS TUF Gaming FX505DT-BQ236 Notebook Specification for Upgrade or Repair
                                This specification for the ASUS TUF Gaming FX505DT-BQ236 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-BQ236 boardview and FX505DT-BQ236 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 09:10 PM
