how to read caps parameters??
+ More Options
Posts
  • yair27
    • Sep 2016
    • 5
    • israel
    hello all, i want to know what mean any parameters at caps?
    and what is important if i want to search at another board for replacent.
    thanks!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: how to read caps parameters??
    2.2uf is the capacitance, 10% is the tolerance, 100v is the voltage, X5R is the type and 1206 is the size.
    • yair27
      • Sep 2016
      • 5
      • israel
      thanks for that...can i replace this cap with
      capacitance 1000pf
      tolerance 10%
      voltage 100v
      X7R
      601
      or the capacitance is to small?
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        Use an online converter
        https://www.unitconverters.net/elect...microfarad.htm
        1000 pF = 0.001 mF
        Obviosly is too small, I recommend the same capacitance because it is described as CRITICAL
        • yair27
          • Sep 2016
          • 5
          • israel
          thanks!
          • ibdoctorate
            • Feb 2020
            • 5
            • Nigeria
            Good info. helpful
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • SwedishDiesel
              Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
              by SwedishDiesel
              Howdy folks,
              I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
              10-30-2021, 12:47 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
              by momaka
              03-15-2023, 10:17 PM
