Dell Inspiron 15 (3542) - No Display - HELP!
  • Thabto
    • Oct 2009
    • 32
    Hello. I have a Dell Inspiron 15 (3542) Core i3 laptop. Motherboard number: Cedar 13269-1 FX3MC REV A00. The laptop does not display. When you press the power button, the fan spins, after a few seconds the laptop beeps (4 beeps). *This suggests a memory issue but the same memory chip works fine on another laptop and is indeed the correct DDR3L required by the laptop. *I have measured all coil voltages, they are all present. I have inspected the ram slot, its ok. I have flashed the bios chip, cleaned the RAM and slot but the laptop still will not display. I get the following voltages on the RAM slot:
    Pin 1, 126, 203, 204* - 0.675v
    Pin 199* - 3.31v
    Pin 75, 76, 81, 82, 87, 88, 93, 94, 100, 105, 106, 111, 112, 117, 118, 123, 124** -* 1.363v
    Pin 30 - 1.363v
    Any ideas, Anyone ever had this problem? I am stuck. Let me know. Thank you.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Dell Inspiron 15 (3542) - No Display - HELP!
    Make sure the 4 beeps do not indicate a graphics memory issue.
    What did happen to this laptop?
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      try to connect external monitor then power on.. most laptop uses the upper memory for use of the graphic memory try to test the memory with dos intense memory tester.
      • Sifax
        • Oct 2022
        • Algeria
        Pin 199* - 3.31v
        Pin 30 - 1.363v
        I have the same problem
        • Sifax
          • Oct 2022
          • Algeria
          Anyone can help me to resolve this problem
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Backup your old BIOS bin flash with a working bin If this method doesn't work, there are additional signals to check in the RAM slot using the DSO.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              SDA/SCL communication between ram slot and PCH may give a hint of the problem.
              • adamgouadma
                • Jul 2017
                • 195
                • setif
                Dell Inspiron 15 (3542) Cedar 13269-1 FX3MC REV A00.
                when Charging mode: The helicopter rotates and then emits a sound And there is no screen
                I think the BIOS is corrupted
                Please help clean this file
                  • 21467
                  Post bios requests in the "Bios requests ONLY!" sub forum.....
                  • adamgouadma
                    • Jul 2017
                    • 195
                    • setif
                    Thanks, I didn't notice
                    • pkk8929kk
                      • Jan 2023
                      • 18
                      • India
                      did flashing Bios helped?
                      my laptop also gives 4 beeps no display
                      • mon2
                        • 14575
                        4 Beeps on a Dell = memory failure.
                        • pkk8929kk
                          • Jan 2023
                          • 18
                          • India
                          Do i Need to replace the RAM stick or is it internal?
                            DELL Inspiron 3542 Notebook 3000 Specification for Upgrade or Repair
                            This specification for the DELL Inspiron 3542 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3542 boardview and 3542 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3542...
                            09-06-2024, 08:00 AM
