Mac Mini Late 2018 |A1993| Fan Connector Damage & Lots of Weird Issues
  • grimacelord
    • Jan 2017
    • 354
    Hi guys.
    I have a customer's Late 2018 Mac Mini in for a ripped fan connector after the customer tried upgrading his RAM.
    Some pretty hefty damage occurred because the connector was ripped off entirely including all 6 pads for the fan connector. The connector on the end of the fan itself was also completely ripped off exposing all 6 wires. There is also an exploded component with what appears to be a resistor or filter. Not sure? (See pic). macOS also doesn't boot. Apple logo comes on screen and then moves to the question mark folder. Cannot boot from USB or Recovery partition. Any attempts to boot into another mode/keyboard combination/PRAM or SMC reset/external drive makes the Mac move to Internet Recovery which it tries, but then fails with error -1008F.
    I tried rebuilding the pads and replacing the connector - no luck. Fan does a half spin every few seconds endlessly. So then I tried removing the connector I just soldered in place and directly soldering all 6 wires straight to their respective pads. No luck. Same deal. Half a fan spin every couple of seconds.
    So I thought perhaps the customer damaged the fan itself in addition to everything else. So, I ordered a new one and repeated the same process above. No luck. Same deal. Half a fan spin every couple of seconds.
    So then I did some probing on the pads where the connector once was. I took some notes and put together a picture to help explain it. (see pic)
    I did take a normal 12v PC fan, cut the connector off, solder it's positive wire to 12v and it's negative to ground and it does spin normally. I even went as far as making a "Frankenstein fan" from the original fan casing and a PC fan motor/blades but it doesn't adequately keep the Mac Mini cool. It overheats and artifacts appear on the screen after a few minutes.
    I even tried using my modded fan in addition to this user's mod:
    https://egpu.io/forums/psu-cables/2x...zor-x-fan-mod/ (See Mod #1)
    This did allow the Mac Mini to stay on longer before it overheated, but ultimately it wouldn't do the job either. After seeing a diagram of the design of it's cooling system, it's easier to see why.
    Diagram of airflow design for the Mac Mini cooling system
    I cannot find a pinout of the 2018 mac mini fan to know what wires/pins are for what. All I know is the 12v pin/wire. If I had this pinout, things might be a bit easier. I've tried experimenting with a bench power supply and the wires of the fan to determine what is ground/etc, but no combination of checking these wires makes the fan spin outside of the Mini. Only when soldered to the board will it show a small glimmer of life with that half spin.
    Knowing that there are no schematics available for the 2018 Mac Mini (at least from my attempted searching), nor is there a lot of repair information out there, I am running out of ideas. If someone has a pinout of the fan/connector or better yet, a schematic, that would be awesome. If someone can guide me in the right direction, that would be equally awesome.
    If someone owns a A1993 Late 2018 Mac Mini and could take some measurements of their own fan connector and that component that blew up, that would be helpful even, because without all of this, I'm sort of lost now. Even if I manage to get the fan working properly again, I still have the issue with macOS not booting and not allowing me to boot from anything to reinstall it or even Internet recovery. Ugh.
    Hopefully I have explained everything well enough. If you have any questions or would like some pictures/measurements, just ask.
    Thanks.
    (Attached picture below illustrates the damage I have determined)
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Mac Mini Late 2018 |A1993| Fan Connector Damage & Lots of Weird Issues
    No schematics available for any Mac Mini.
    The fan is probably PWM controlled, and it has a tachometer to report the speed. Meaning that it should have at least 4 separate connections like PC fans with 4 wires: VCC, PWM, Tach, GND.
    If tachometer doesn't work I'm pretty sure the machine won't like it and will throttle and to make the fan spin at full speed, diagnostics should also report an error.
    About the inability to boot, it sounds like it is Secure Boot full security mode kicking in, so it's trying to update from Internet Recovery. It's a bit weird as the original issue isn't related to SSD, so there may be more damage. In any case you should eventually be able to enter Internet Recovery, try the various key combinations, make sure Internet works properly and you don't have a proxy/firewall causing problem. You can also take a look at Apple support page: https://support.apple.com/en-us/HT206989
    • grimacelord
      • Jan 2017
      • 354
      Thanks for the reply. The bit about needing at least 4 wires to function is especially helpful. Any suggestions on how I can wire the 4 back into their respective circuits? I can run trace wires if I have to. Finding where they go is going to be time consuming without a schematic. Any suggestions? The customer said he doesn't care if it runs full speed and it's noisy. He just wants it to work.
      • H15teve
        • Feb 2023
        • China
        Hey grimacelord, I found a video on youtube which the author posted the pin diagram in the comment.https://www.youtube.com/watch?v=fok0l5pjjGg
        • summerwhite
          DJI Mini Pro 3 missing components near camera connector
          by summerwhite
          I have a DJI drone that is not displaying a video feed anymore after a repair.
          When tearing down the DJI drone to fix the armature there was some hot glue next to the camera connector that i had to remove.
          Now there are missing components either because they got pulled off or because they where never placed.
          I have two reference images from XXZ and a photo of mine.
          I'm truely hoping someone has another DJI Mini Pro 3 that they can help me identify what these components are and if they are necessary.
          On the board view from XXZ they...
          04-06-2025, 11:15 PM
          HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
          This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-12-2024, 03:36 PM
          HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
          This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
          09-12-2024, 02:20 PM
          09-12-2024, 02:15 PM
          HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
