lenovo b470 turns on only on battery
    Re: lenovo b470 turns on only on battery
    Your PU3801 is shorted , did you check it ! make a wire between pin 1 and 8 just to confirm that.
    repeat taken voltage on pin 1-3 / pin 4 / pin 5-8 and post it
      anyone can help please i still cannot solved this problem
        yes pulled out and test it both pin 1 and pin 8 PU3801 hve 19v
          Please see post #81
            i checked on schematics page 81 is blank
              No bro , i m not meaning schematics
              Post 81 = Your PU3801 is shorted , did you check it ! make a wire between pin 1 and 8 just to confirm that.
                i checked it pn 1 and pin 8/ both have 19v of PU3801
                  Without PU3801 soldered and you got 19V at pin 8 !!!
                  or did you make a wire btween 1 and 8!
                    with the PU3801 removed pin has 19v but pin8 0v
                      I try to make a wire from pin 1 to pin8 with PU3801 Removed still cannnot turn on with charger only plugged and both battery and charger plugged in
                        still not solved this problem anyone can help on this please
                          I'm really confused by all of this, 5 pages of random measurements and component replacement and I can't follow the troubleshooting process.
                          Where are we now? Does it still turn on from battery but not from AC adapter?
                          Are all components properly soldered back on the board (and no random jumper wire!)?
                          Do we have the 19V power rail (DCBATOUT)?
                          Is any of PU3801, PU4001 and PU4002 shorted drain/source/gate?
                            @piernov laptop can turn on with battery only plugged in but cannot turn on with charger only plugged in and both charger and battery plugged in. PU3801 drain 0.700 source and gate both have pu4001 and pu4002 both drain, source have 0.700v and gate have 0l
