Dell Latitude D630 won't power up
  • grss1982
    • Mar 2007
    • 225
    • Philippines
    Hi everybody. Been a while since i posted here but in any case, what I've done so far with this D630 issue:
    1) Removed battery and held down power button for 30 seconds but still won't power up while using just the power cord.
    2) Removed battery and held down power button for 60 seconds but still won't power up while using just the power cord.
    None of the LEDs light up when I plug in the power cord except for the battery LED which flashes green for less than a second whether I have a battery attached or not.
    Battery also never charges.
    Do I have a dead laptop here?
    Thanks for any help.
    CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
    GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
    Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
  • Alfa is auto
    • May 2013
    • 83
    • Finland
    Re: Dell Latitude D630 won't power up
    wich gpu ?
    • manuel.it.solution
      • May 2020
      • 30
      • Ghana
      Please have you tried With another charger?had the Same issue but after changing the changing the charger the laptop turned on
      • grss1982
        • Mar 2007
        • 225
        • Philippines
        Originally posted by Alfa is auto
        wich gpu ?
        It has an Intel GPU. Not the problematic Nvidia one that I've read about in the web.
        If it helps Service tag is 3TFMNH1 which the Dell web site gives me the following result: https://www.dell.com/support/home/en...Zz090/overview
        It's not one of those bog standard chargers. I'll try to look for one though and see if that helps.
        • Oj computer
          • Dec 2021
          • 38
          • Nigeria
          Good day everyone
          I have dell LA 3301p stock at window logo.
          I proceed to program bios but after that my display is not coming again.
          I've used like 4 different files and I've still return the backup file but same thing.
          All coil voltages present.
          Pls helpppppp me am highly tired.
