Dell alienware c912p rev 2.0 dead
  • ritch50
    • Feb 2011
    • 8
    Hi, hope somebody can help. Noob here.
    Dell Alienware 15 LA-C912P REV2.0 laptop here that I have No history of. Don't know what previous has happened just dead no power at all.
    The only thing I can find is what looks to be a burnt resistor? I cannot see the value, have attached the pic.
    The laptop does not power at all, nothing. There is 19V at 1 side of the resistor, 0.89 at the other.
    Any pointers would be amazing please!
    Thank you and good health, Rick
  • peste
    • Dec 2016
    • 13600
    • ROMANIA
    Re: Dell alienware c912p rev 2.0 dead
    see which route has the resistance part with 0.89v, if it reaches pin 28, CI PU 700, the resistance has 10 ohms.
    • ritch50
      • Feb 2011
      • 8
      Hi Peste, thank you for your reply!
      I found this with multimeter:
      pin 28 vcc 0.86v
      pin 6 acdet 2.57v
      pin 5 acok 0.19v
      pin 4 acdrv -0.05v
      Do you think that it is just a burnt resistor causing fault?
      Thank you,
      Ritch
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        That resistor is burnt for sure as you are aware. Remove it from m/b. check resistance on the side where you get 0.89V. You need to replace the resistor as @peste suggested but do check resistance on 0.89V side. If there is short on the 8.089v side, resistor will burn out again.
        • ritch50
          • Feb 2011
          • 8
          Hi mcplslg123,
          Thanks for the reply, I checked and no short it appears so replaced the 10 ohms resistor and it dosen't burn out so 19v going to pin 28 but still dosent fire up
          Thanks, Rick
          • emestee
            • Dec 2019
            • 228
            • Bulgaria
            What about ACOK and ACDRV?
            • ritch50
              • Feb 2011
              • 8
              Hi
              ACOK : 0v
              ACDRV: 0v
              • emestee
                • Dec 2019
                • 228
                • Bulgaria
                Originally posted by ritch50
                Hi
                ACOK : 0v
                ACDRV: 0v
                So the charger IC won't start, look in its datasheet how ACOK is formed, and it'll tell you where the problem is - or that the IC is dead. The first place to look would be the minimal voltage on ACDET, and whether the LDO output of the IC is shorted.
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • ph st
                  Dell Alienware 17 R3 LA-C912P
                  by ph st
                  Hey guys,
                  i do have some troubles with this Mainboard.
                  I just got it from my brother after it had some real damage after a huge flood.
                  I cleaned everything so far and i try to make it work again.
                  The first issue i experienced was that the inductor (as shown) was not completly soldered any more.
                  I checked all the other with a multimeter and they seem to work fine.
                  As i am not sure what exactly the purpose of this part is, so i am not sure if its damaged and how to check it. I checked the schmematic, but did not get a clue hahaha....
                  12-02-2024, 02:10 PM
                • GeeksOnCall580
                  Dell-Alienware-X15-R2-Compal-HDS70-LA-L613P-Rev-1
                  by GeeksOnCall580
                  ALSO FOR THE X17 VER:1.0 AND 2.0 SCHEMATIC! FOR ALL OF YOU GUYS!...
                  08-30-2025, 08:21 PM
                • Francesc V.
                  Dell dockstation WD15 is dead
                  by Francesc V.
                  Hi:
                  A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
                  Here are the findings, followed by good pictures. :-)
                  When pluged in, LED3 glows
                  Measuring some voltage in the circuit.
                  Inductors
                  - PL202 has 5V
                  - PL201 has 3.3V
                  - PL300 has 1V
                  V. Regulators
                  - UT30 has 19v as input and 6V as output. It seems ok.
                  - UT27 (same reference as UT30, has no input/output voltage).
                  Thermal find...
                  07-09-2025, 12:12 AM
