A1707 no CPU Vcore
  • megabitit
    • Apr 2020
    • 10
    • Portugal
    A1707 no CPU Vcore
    Hello Guys,
    I have an A1707 820-00281-A, that doesn´t boot, that has 19.5V and stays at 20mA current, and drops to 0mA. All major rails voltages are ok, but I have 0V on L7211. I'm thinking in replacing the U7210.
    Can anyone help me?
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: A1707 no CPU Vcore
    If you only have 20mA you are probably missing more than just CPU VCore.
    Please go down the list of power rails to check their voltage so we can understand what state the board is in. Also describe history of the machine (liquid damage, physical damage…) and confirm you are using a known good genuine Magsafe 87W.
    And don't replace U7210, there is no reason to.
    • MobileXT
      • Oct 2012
      • 196
      Do you have PPBUS_G3H?
      • megabitit
        • Apr 2020
        • 10
        • Portugal
        Thank you guys.
        Yes, i do have PPBUS_G3H.
        I´m measuring all the power rails, and i´ll post them hear today. If anyone can help me, i´ll be apreciated guys.
        • megabitit
          • Apr 2020
          • 10
          • Portugal
          Thank you piernov. I´m measuring all the power rails, and i´ll post them hear today. If you can help me, i´ll be apreciated.
          • megabitit
            • Apr 2020
            • 10
            • Portugal
            Yes MobileXT, i do have PPBUS_G3H.
            • megabitit
              • Apr 2020
              • 10
              • Portugal
              Good afternoon,
              The board just stoped working. It has no liquid damages or anything else... just stop working.
              Here are the measurements I got:
              PPBUS_G3H = 12.58V
              PPBUS_HS_CPU = 12.58V
              PPBUS_HS_GPU = 12.58V
              PPBUS_HS_OTH5V = 12.58V
              PPBUS_HS_OTH3V3 = 12.58V
              PPBUS_S4_HS_TPAD = 12.58V
              PPVCC_S0_CPU = 0V
              PPVCCSA_S0_CPU = 0V
              PPVCCGT_S0_CPU = 0V
              PPVCCIO_S0_CPU = 0V
              PP3V3_G3H = 3.4V
              PP3V0_G3H = 3.0V
              PP1V2_S3 = 0V
              PP1V2_S3_CPUDDR = 0V
              PP1V2_S0SW = 0V
              PP0V6_S0_DDRVTT = 0V
              PP0V6_S3_MEM_VREFD0_A = 0V
              PP0V6_S3_MEM_VREFCA_A = 0V
              PP0V6_S3_MEM_VREFD0_B = 0V
              PP1V8_SUS = Fluctuates between 1.4V and 0.5V
              PP1V8_S4 = 0V
              PP1V8_S3 = 0V
              PP1V8_S3_MEM = 0V
              PP1V8_S0 = 0V
              PP1V0_SUS = Fluctuates between 0.6V and 0V
              PP1V0_S3 = 0V
              PP1V0_S0SW = 0V
              PP3V3_S5_T139 = Fluctuates between 0V and 3.3V
              PP3V3_S4_SOC_PMU = 0V
              PP5V_S0_T139 = Fluctuates between 1V and 0.5V
              PP3V3_S5 = Fluctuates between 0V and 5V
              PP3V3_SUS = 0V
              PP3V3_S4 = 0V
              PP5_S4 = 0V
              PP5V_S0 = 0.5V
              PP3V3_S4_T151 = 0V
              PP3V3_S0 = Fluctuates between 0V and 0.5V
              Can anyone help?
              • piernov
                • Jan 2016
                • 4435
                • France
                Originally posted by megabitit
                Good afternoon,
                I assume that's a typo since PP3V3_S5 should only go up to 3.3V.
                Also I don't see PP5V_S5 in this list (and some others but should not be relevant for now).
                Measure resistance to ground on PP3V3_SUS and PP5V_S4.
                • shaban
                  • Oct 2011
                  PP3V3_S5_T139
                  never fluctuates constantly 3.3 volts
                  • megabitit
                    • Apr 2020
                    • 10
                    • Portugal
                    Hello piernov.
                    the PP5V_S5 = Fluctuates between 0V and 5V
                    The resistance of the PP3V3_SUS = 3M Ohm
                    The resistance of the PP5V_S4 = 5M Ohm
                    The PP3V3_S5 = Fluctuates between 0V and 3.3V
                    I have no idea of what's causing this
                    • megabitit
                      • Apr 2020
                      • 10
                      • Portugal
                      The PP3V3_S5_T139 = Fluctuates between 0V and 3.3V
                      • megabitit
                        • Apr 2020
                        • 10
                        • Portugal
                        Does anyone has any ideas? What should I check now?
                        • sunny1234
                          • Dec 2020
                          • Berlin
                          Have you solved the problem, if yes what have you done? If not, can anyone help here I have the exact same problem.
                          • meineiid
                            • Jan 2019
                            • 9
                            Hi there,,
                            i have the same issue too
                            • josuecas
                              • Mar 2019
                              • Honduras
                              replace u7800
                              • barry101
                                Apple 820-3662 VCore shorted to ground.
                                by barry101
                                Hi, Would appreciate some help.
                                I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                Get charger light but no fan spin or chime. No liquid damage.
                                Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                06-24-2025, 07:34 AM
                              • Francisco.s
                                CPU vcore missing in HP workstation Z2 Mini 4G
                                by Francisco.s
                                Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
                                The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
                                It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
                                Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
                                The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
                                I wonder which circuit generates this enable...
                                04-22-2024, 12:35 PM
                              • mikzs
                                Rx580 8gb sapphire nitro+ turn off vcore randomly
                                by mikzs
                                Hello, this is my first post, English is not my native language but I hope you understand me. I recently got a 580 that didn't turn on the typical short mosfet, as I didn't know exactly which one was short, I unsoldered them until I got the bad one out, I was able to remove the short and identify the bad mosfet, the gpu gives video again! but it has a problem that completely turns off vcore at random times or if I try to put a load on the gpu vcore drops to 0 I don't have much idea why because I don't know much about sapphire, any advice on where I could start looking or what problem it could...
                                11-06-2023, 12:28 PM
                              • jm942
                                Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                                by jm942
                                My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                                I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                                I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                                I did voltage injection on the cpu with 0.7V and i have a current...
                                07-11-2024, 05:11 AM
                              • kotel studios
                                Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                                by kotel studios
                                Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                                Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                                So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                                What I've tried so far:
                                replace the original N-MOSFETs with beefier 60V ones for testing
                                Resolder the resistors near the Vcore Jumper block
                                Short Vcore...
                                05-25-2025, 01:46 AM
