LENOVO g50 -80
  • ghost73
    • Feb 2020
    • 28
    • GREECE
    LENOVO g50 -80
    hello from Greece
    I have a lenovo G50 -80
    The problem is in internal screen
    in external screen the laptop is working perfect
    but in the internal screen i dont see nothing ... no backlight no picture ..
  • peste
    • 13585
    • ROMANIA
    Re: LENOVO g50 -80
    check display, LVDS cable, (display socket, and motherboard), reflow cipset video trial only, use flux paste, be careful not to fry it.
    • bayuseto
      • Mar 2013
      • 13
      • Indonesia
      Re: LENOVO g50 -80
      you try internal screen other
      • BMCappelletti
        Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
        by BMCappelletti
        Hi everyone.
        Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
        Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
        Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
        02-18-2025, 12:22 PM
      • ahoonid
        MacBook A1990 vertical stripes on external screen
        by ahoonid
        Hey everyone,
        I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
        The board is neat. Not opened before for sure. Just a little dust, nothing more.
        Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
        06-20-2025, 08:54 AM
      • g1150
        Lenovo G565 Laptop , LCD not turn on, external terminak ok.
        by g1150
        Lenovo G565 Laptop onboard LCD Display does not turn on.
        Only works with external Monitor.
        I am trying to verify that the LCD signals from the motherboard are ok.
        The LCD was working, but over time happened to not turn on more frequently.
        Now dead.
        Possibly the cable from MB to LCD is broken somewhere.
        I just wonder how it is detected if external or internal monitor shall be activated ?
        I found the following schematic on the net:
        Problem 2:
        The graphics chip ATI Mobility Radeon HD5470 seems defective.
        On Win7...
        05-07-2025, 11:51 AM
      • survivalbloke
        HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
        by survivalbloke
        SN: 8CG0213H8W
        ProdID 3C311UA
        This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
        05-08-2025, 12:21 PM
      • viniciussls
        Notebook won’t turn on after screen replacement - Lenovo Legion Silm 5 16IRH8_LOQ 15IRH8 Compal ILG10 LA-M542P Rev 1.0
        by viniciussls
        Good morning everyone, this is my first post and I apologize in advance if there are any mistakes in the post.
        I have a Lenovo Legion Slim 5 16IRH8_LOQ with the typical issue of stripes on the screen, but I made the mistake of replacing the screen without physically removing the battery, thinking that just pressing the SW2 button would be enough – it wasn't. The board showed consumption, with LED6301 lit up and PU301 getting very hot. I replaced PU301. Now, the board is not working correctly, but it has no consumption, LED6301 stays on, and I haven't found any other signs of a short...
        04-02-2025, 01:40 AM
