Hp omen 15-DC. 3.3v ALWS only 1.36v !!! 5v present!
  • Weelcup
    TopTech
    • Oct 2017
    • 302
    Hi friends
    I have omen 15-DC motherboard. 3.3V power rail only gives 1.36V !?
    5V is present.
    I replaced the 3.3V provider IC but same issue.
    3.2v present on power button.
    I also replaced super io chip but same!!
    Any suggestion?
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Hp omen 15-DC. 3.3v ALWS only 1.36v !!! 5v present!
    Remove one Pad of coil 3ALWS and check the Voltage again, check the resistance to ground out put side of 3V line, Upload the Schematic or MB ID ?
    • Weelcup
      TopTech
      • Oct 2017
      • 302
      Thanks for following up,
      When rermoving one side of the 3.3v rail. There is 18.6V on the IC side of the rail.
      Unfortunately, there is no schematic available for this motherboard.
      The motherboard id is, DA0G3DMBCE0 Rev E.
      The 3.3V ic is RT6256B.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3593
        • slovakia
        r u sure u measure it right?
        19V on that rail will butn RT ic and all 3,3V components
        • Weelcup
          TopTech
          • Oct 2017
          • 302
          Well, it is strange to me too. Remember, when i connect both sides of the rail it produce only 1.36v. But if i disconnect one of the rail sides, the ic side becomes 18v. I mean the rail side that gets the volt. From the ic.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3593
            • slovakia
            rail dont get volt from chip but from step down circuit . u can have shorted high side mosfet, but that means all components on 3,3V si must be burnt
            • Weelcup
              TopTech
              • Oct 2017
              • 302
              Maybe, but i have checked all mosfets. Non is shorted to ground!. Besides 19v is present. 5.1v is present. Only 3.3v is missing.
              I suspect the pch. Hoever, it is not shorted. I also suspect the graphic chip but not shorted as well. Soooo confusing.
                • 20898
                On what pin do you have 5.1V present .The RT6256B and C have a different pinout
                • Weelcup
                  TopTech
                  • Oct 2017
                  • 302
                  Sorry for the confusion, i was taking about the rt6256C output not B. Just to clarify that 5v is present in the abscense of 3.3v...
                    • 20898
                    Ok start again then, post voltage for all pins and resistance to gnd .
                    • Weelcup
                      TopTech
                      • Oct 2017
                      • 302
                      Thanks for following up. Actually i managed to find the issue.
                      It turned out that the charger was issue. Everthing seems to work fine after replacing the charger. Although the old charger was tested and everything thing was ok with the charger even the voltage on the middle pin was there. But it was generic180w charger.
                      This laptop only works with hp original charger as there were no way to get it to pass the 3.3v correctly with the generic charger. Very weired !! But this is the solution.
                      Thanks for everyone who advised and helped me ..
                      Kind regards
                        HP OMEN OMEN by Desktop PC - 870-118na OMEN 870 i7-6700 Specification for Upgrade or Repair
                        This specification for the HP OMEN OMEN by Desktop PC - 870-118na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-118na boardview and OMEN OMEN by Desktop PC - 870-118na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-12-2024, 03:44 PM
                        HP OMEN OMEN by Desktop PC - 870-128na OMEN 870 i7-6700 Specification for Upgrade or Repair
                        This specification for the HP OMEN OMEN by Desktop PC - 870-128na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-128na boardview and OMEN OMEN by Desktop PC - 870-128na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        HP OMEN OMEN by Desktop PC - 870-104na OMEN 870 i5-6400 Specification for Upgrade or Repair
                        This specification for the HP OMEN OMEN by Desktop PC - 870-104na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-104na boardview and OMEN OMEN by Desktop PC - 870-104na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        HP OMEN OMEN by Desktop PC - 870-117na OMEN 870 i7-6700 Specification for Upgrade or Repair
                        This specification for the HP OMEN OMEN by Desktop PC - 870-117na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-117na boardview and OMEN OMEN by Desktop PC - 870-117na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        HP OMEN X OMEN X by Desktop PC - 900-010 OMEN X i7-6700K Specification for Upgrade or Repair
                        This specification for the HP OMEN X OMEN X by Desktop PC - 900-010 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-010 boardview and OMEN X OMEN X by Desktop PC - 900-010 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
