6050A2493101-MB-A02 No Starting Problem
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 348
    • India
    Hi
    6050A2493101-MB-A02 Model -2000-2d03Tu
    Board dont turn ,dont stay ON. power Button led keeps flashing
    no power at coil L6710 (PVAXG) replaced u6710 .P5V0A volt present at pin 6
    no power L6610 &L5520 (PVCORE) replaced U6600
    Strange observation when i connect Debug in board stays ON for 30-35 seconds PCH is heating little bit
    Any thing i am missing,
  • tranquility
    Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
    by tranquility
    i want to repair an Onkyo TX-NR809 receiver.
    symptoms:
    on power on, display appears and i hear one click. enue functions is given.
    - no hdmi output
    - audio output not tested, but i think it is not there
    - usb sticks are not recognized
    if i read out the chips with display+standby button + tone+
    both dts show only ????
    chip is D830K013BZKB4
    things i have done:
    - reflow of the dts chip without taking off and reballing
    - changed the aluminium caps without the big one with 25v because i dont...
    08-25-2025, 01:04 AM
  • ravi_1617
    Lenovo B540 ,Starting Problem
    by ravi_1617
    Hello !
    Model Lenovo B540
    Board Details 09244-1
    LA14 DIS MB
    48.4DMO4.01.1
    This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
    when connected CMOS dont start.
    3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
    One more thing i want to mention ( by mistake i started at...
    10-14-2025, 02:08 AM
  • PeteH
    Dell Precision 5520 / LA-E331P r2.0 starting into CPU-failure
    by PeteH
    I have here a broken Dell Precision 5520 / LA-E331P r2.0 to play with
    I found the schematics for r1.0, but not for r2.0.
    The situation
    - the laptop turns on, but the screen stays black -> the dell diag-LED shows the blink pattern for "CPU failure"
    - the voltages close to the CPU stay at low
    - I don't see any hotspots on the PCB (thermal imaging camera)
    - some spots/areas on the PCB indicate some kind of liquid "damage"
    Before I start digging though 70+ pages of schematics, maybe somebody...
    10-12-2025, 07:54 AM
  • SuperAman
    HP 15 EPK50 LA-G07EP not starting up on battery?
    by SuperAman
    Hi guys, I got an HP 15 mobo # EPK50 LA-G07EP rev 2.0 not starting up on battery? Recently the battery completely died, wouldn't hold a charge, so I used it for like 3 or 4 days until I ordered a new battery. I ordered a new "OEM" battery and replaced it. It wouldn't start with new battery, figured it was dead and plugged it up and powered it on to see that new battery was like 60% charged. So it seems It won't start on battery if it is not plugged in. It charges fine and lets me use it while not plugged in. If I use it and shut it down and try to power it back on it'll start from power...
    12-17-2024, 07:03 PM
  • Braith
    iMac (2012 model) A1419, EMCNo: 2639 not starting up
    by Braith
    Hi, EMC 2639 .iMac not starting up. Single dim diagnostic LED (LE0301) flashes off briefly when power button pressed. Working through supply rails at present (PP5V_S5 appears shorted to ground but still early days)
    Using Boardview 820-4652 but not sure if that is correct one to use. Have searched Forum but only found bios found for 2639 so far.
    Have also tried 820-00134-08 and 820-3478 but have noticed discrepancies compared to my board.
    If anyone has correct BOARDVIEW and SCHEMATIC for a EMC 2639 I would really appreciate it before I get too far into this.
    11-08-2024, 01:12 PM
