6050A2493101-MB-A02 No Starting Problem
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 345
    • India
    Hi
    6050A2493101-MB-A02 Model -2000-2d03Tu
    Board dont turn ,dont stay ON. power Button led keeps flashing
    no power at coil L6710 (PVAXG) replaced u6710 .P5V0A volt present at pin 6
    no power L6610 &L5520 (PVCORE) replaced U6600
    Strange observation when i connect Debug in board stays ON for 30-35 seconds PCH is heating little bit
    Any thing i am missing,
  • SuperAman
    HP 15 EPK50 LA-G07EP not starting up on battery?
    by SuperAman
    Hi guys, I got an HP 15 mobo # EPK50 LA-G07EP rev 2.0 not starting up on battery? Recently the battery completely died, wouldn't hold a charge, so I used it for like 3 or 4 days until I ordered a new battery. I ordered a new "OEM" battery and replaced it. It wouldn't start with new battery, figured it was dead and plugged it up and powered it on to see that new battery was like 60% charged. So it seems It won't start on battery if it is not plugged in. It charges fine and lets me use it while not plugged in. If I use it and shut it down and try to power it back on it'll start from power...
    12-17-2024, 07:03 PM
  • Braith
    iMac (2012 model) A1419, EMCNo: 2639 not starting up
    by Braith
    Hi, EMC 2639 .iMac not starting up. Single dim diagnostic LED (LE0301) flashes off briefly when power button pressed. Working through supply rails at present (PP5V_S5 appears shorted to ground but still early days)
    Using Boardview 820-4652 but not sure if that is correct one to use. Have searched Forum but only found bios found for 2639 so far.
    Have also tried 820-00134-08 and 820-3478 but have noticed discrepancies compared to my board.
    If anyone has correct BOARDVIEW and SCHEMATIC for a EMC 2639 I would really appreciate it before I get too far into this.
    11-08-2024, 01:12 PM
  • DynaxSC
    Weired MSI B560M PRO (MS-7D20) - not starting with 11-th gen. CPU, 10-th gen. OK
    by DynaxSC
    I have a very weired problem with MSI B560M PRO (MS-7D20), board is upgraded to the latest BIOS version v1.9.
    The board is normally starting with 10-th gen. CPU, ie. Intel Comet Lake i5-10600K and Celeron G5905.
    However if I install a 11-th gen. Rocket Lake i5-11600K the board powers up, but is immediately stuck on CPU LED, not progressing further. Debug card shows FF, and after restart with long short of Power Button: FE, which is as usually of no help (Reserved for future AMI error codes).
    According to MSI compatibility site the board supports...
    11-04-2024, 04:04 PM
  • stormanimal83
    Gigabyte Aorus X470 not starting randomly..
    by stormanimal83
    still trying to fix my aorus from ebay. had a question about bios functions some time ago. but bios is not the solution in my case as i mentioned first...
    The board is randomly not turning on especially when is was without power for longer periode of time... it can last at least one hour to get it running.
    i dont know how to fix that. its like a dead capacitor issue because if i´m patient enough i get it always up and running. i managed ti install new windows 11 to ssd few minutes ago.
    few pictures..
    04-02-2023, 02:49 PM
  • bpjl
    SEF 551.10 - Error starting the reflow oven.
    by bpjl
    When starting the SEF 551.10 reflow oven, the following problem occurs:
    It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
    PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
    10-17-2024, 06:30 AM
