HP Pavilion 15 (R62) Not charging. shows Amber & White light continuously
  • classicandy
    • Apr 2018
    • 309
    • Nigeria
    Hi Everyone,
    I have this HP Pavilion 15 (R62) that is Not charging. It Alternates between Amber & White charging light continuously when i connect the AC adapter with the battery connected as well.
    Sometimes, It may alternate 2 -3 times before it starts charging normally, while sometimes, it won't charge and if i remove the battery while the AC adapter is still connected, the light goes off (System goes off too).
    The battery is okay, i've tested it on another R62 and it charges normally.
    What can be the cause?
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: HP Pavilion 15 (R62) Not charging. shows Amber & White light continuously
    Originally posted by classicandy
    Hi Everyone,
    Dissemble the board & check near the charging IC or the Fets for bad solder joints
    • classicandy
      • Apr 2018
      • 309
      • Nigeria
      About that, these are the things I've done so far:
      1). I've washed the charging area of the board with a good chemical for cleaning.
      2). I have replaced the Charging IC [BQ24738] @PU5
      3). I have replaced PQ30 & PQ35 MOSFETs
      still no solution yet
      • Techtiger
        • Oct 2014
        • 1602
        • france
        What are the voltage on CN11 with Bat & with out Bat ? & Resistant to ground PL10 or 9
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Voltage on BQ24 all pin?
          • classicandy
            • Apr 2018
            • 309
            • Nigeria
            CN11 [With Battery]
            Pin 1 = 12.71
            Pin 2 = 12.71
            Pin 3 = 2.93
            Pin 4 = 2.94
            Pin 5 to Pin 8 = 0.00
            CN11 [Without Battery]
            Pin 1 = 0.88
            Pin 2 = 0.88
            Pin 3 = 2.99
            Pin 4 = 3.01
            Pin 6 = 0.55
            Pin 5, 7 & 8 = 0.00
            • classicandy
              • Apr 2018
              • 309
              • Nigeria
              PU5 [BQ24738]
              [with Battery] [w/o Battery] [with Battery] [w/o Battery]
              Pin 1 = 19.36 20.01 Pin 11 = 10.94 0.82
              Pin 2 = 19.36 19.92 Pin 12 = 12.72 0.85
              Pin 3 = 17.66 18.15 Pin 13 = 12.75 0.85
              Pin 4 = 9.51 1.30 (dropping) Pin 14 = 0.00 0.00
              Pin 5 = 1.32 1.32 Pin 15 = 1.87 0.00
              Pin 6 = 1.09 1.09 Pin 16 = 6.03 6.03
              Pin 7 = 0.20 0.05 Pin 17 = 18.82 5.91
              Pin 8 = 2.95 3.02 Pin 18 = 16.48 0.88
              Pin 9 = 2.95 3.02 Pin 19 = 12.81 0.88
              Pin 10 = 0.92 0.95 Pin 20 = 17.93 19.60
              • classicandy
                • Apr 2018
                • 309
                • Nigeria
                I've found the problem........
                PR80 which is supposed to be 22 ohms was around 550 ohms. PR80 is between +VAD and Pin 20 of PU5 [BQ24738].
                After replacing it, it is now charging normally. Also, all the voltages on PU5 [BQ24738] are back to normal especially Pin 20 which was around 17.9v [with Battery] which is now 19.5v
                Thanks @techtiger
