ASUS X550JK - No Post with DIMM
  • nrcslim89
    • Nov 2019
    • 129
    • Portugal
    Hello guys, today i have here one X550JK.
    Motherboard Info:
    X550JD REV. 2.0
    P/N: 60NB0680-MB1800
    Now, this board works well with only his onboard memory.
    Turns On, POST, goes to system, everything is fine.
    But once we put any RAM at extra socket, on this case original 8GB PC3(DDR3) on the DIMM, the board turn on well but doesn't make POST.
    And get stuck waiting for POST.
    I already did a BIOS UPDATE well done, with Battery and DC Adpter in with EasyFlash.
    But machine dont seems to recognize any RAM that we put on DIMM Socket.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ASUS X550JK - No Post with DIMM
    Have you cleaned the slot with isopropyl alcohol or similar stuff?? No corrosion on pins?? ram stick tested ok??
    • nrcslim89
      • Nov 2019
      • 129
      • Portugal
      Hello my friend, yes already did that, iso alcohol, theres no corrosion on pins and i tried with another working RAM sticks and nothing.
        • 21197
        Have you tested the onboard RAM .
        • nrcslim89
          • Nov 2019
          • 129
          • Portugal
          Yes, onboard RAM works fine, it let me goes to system and windows.
          But with RAM on DIMM Socket forget... no POST
            • 21197
            Test the onboard RAM with memtest86 .The onboard ram can be disabled if theres any problem with it.
            • nrcslim89
              • Nov 2019
              • 129
              • Portugal
              Ok test is done and for 5 times its about 60 Min almost testing... nothing of errors...
              • piernov
                • Jan 2016
                • 4437
                • France
                Try with DDR3L just to make sure…
                I have an X550LC board with the same problem, haven't been able to solve it. Before it stopped working completely with a RAM stick, it was taking several minutes to turn on (with a RAM stick), Obviously I flashed BIOS but that didn't solve it (or I was very unlucky to get 2 or 3 BIOS with problem with removable RAM). RAM slot tester didn't show anything wrong.
                • nrcslim89
                  • Nov 2019
                  • 129
                  • Portugal
                  I did the test with memtest, only with on-board memory, I will try to test and wait for post with RAM on socket DIMM and see if there's POST after some time and test with memtest again.
                  But I think there's a problem with socket because when I put any RAM do the same.
                  • nrcslim89
                    • Nov 2019
                    • 129
                    • Portugal
                    HI there, I already flash BIOS to last release available at support website, does not solve the issue like you, I keep RAM stick at socket for 1 day, all time turned ON, nothing new... No Post at all.
                    I try a old pci post card I have here but seems it doesn't do nothing... Show "no" and on 4 digit (04f1).
                    Could be a problem from southbrige?
                    • Lukosiukas
                      • Jul 2018
                      • 106
                      • Lithuania
                      Long shot, but maybe someone found the fault causing no post with removable dimm ?
