boardview error pls help me.
  • gsmtim
    • Oct 2018
    • 33
    • philippines
    hi guys i need you help how to fix this kind of error in boardview software?
    Error: ".brd" allegro is under development
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: boardview error pls help me.
    Download Allegro Free Viewer from official Cadence website.
    • gsmtim
      • Oct 2018
      • 33
      • philippines
      how? sir still error
      • Actionkindaguy
        MSI MEG Godlike x570 motherboard - need schematic and boardview, USB3 error
        by Actionkindaguy
        MSI MEG Godlike x570 motherboard - need schematic and boardview. I have accidentally plugged in the wrong usb plug into a usb3.0 connector on front panel of PC resulting in temporarily shorting out the port. (I know it was really stupid, It was dark in my room and was rushing). I shutdown the computer and now after an immediate restart I get an overcurrent error on boot up saying my PC will shut down in 15 seconds. If I let the computer sit for about 35 minutes, I then can boot the PC without getting error. What I am hoping to find out is what parts were affected by my stupidity. Anyone have any...
        05-06-2024, 09:41 AM
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        Replaced emmc.
        Terminal log
        UART
        AC_ON
        E-B
        FDE enabled
        06-01-2025, 02:11 AM
      • sushilachuthan
        APC UPS error P13
        by sushilachuthan
        one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
        the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
        The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
        We replaced the SCR with new device,, but the device is not power on as expected.
        Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
        09-26-2025, 09:00 AM
      • Zakyn
        MSI MAG B550 TOMAHAWK - CPU error, boardview REQ
        by Zakyn
        Hi, I've MSI MAG B550 TOMAHAWK, which stuck on CPU error (red EZ debug LED is on).
        1. I've tried to flash BIOS from USB with no success (stuck on red LED blinking).
        2. No component is overheating.
        Does anyone have boardview of this mobo? I would like to trace the problem, but without boardview is pretty hard task. Thanks for any help.
        09-05-2023, 05:01 AM
      • Superbee_dad
        Sharp 80” long short flash backlight error - Help
        by Superbee_dad
        Hello Sharp TV experts
        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
        01-24-2025, 11:51 PM
