HP Probook 450 G1
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    HP Probook 450 G1
    Hi
    I have a strange fault with this HP probook 450 G1.
    When I plug in the power starts the laptop himseslf , spins the fan fast, no screen and flash the caps lock + numlock 7 times white. , all the power supply's are there.
    I have no schedule.
    Can somebody help me what can be the problem?
    best regards
    Steve
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: HP Probook 450 G1
    i dont see 7 blinks in hp manual. after 6 blinksisonly continuous blinks
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      Hi sorry i was wrong it is 5 times blinking.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Check cmos battery.Flash bios.
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          I replaced the cmos battery is the same
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            Anyone has more ideas
            Regards
            Steve
            • peste
              • Dec 2016
              • 13600
              • ROMANIA
              have you tried a clean bios? ..
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                No not yet i ordered a bios programmer. What number do i need for asking a dump. I have never flash a bios. I order ch341A programmer
                Best regards
                • Stevedb
                  Stevedb
                  • Feb 2018
                  • 624
                  • Belgium
                  Hi what numer do i need to ask a. Biosdump and flash the bios.
                  What also strange is when i will power up the laptop with mu power supply or another hp charger or my toshiba charger with adapter piece the charger light blinks then.
                  Is the problem then the bios?
                  Best regards
                  Steve
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    5 blinks is general system board failure
                    board is checking charger with middle pin if it is original charger and if it have enough wats. if not it wont let u charge or power on
                    • Stevedb
                      Stevedb
                      • Feb 2018
                      • 624
                      • Belgium
                      Thanks for the reply ktmmotocross.
                      so when you do not have a original charger you can never test the board then?
                      How can I fix this laptop then?
                      Flash bios?
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3627
                        • slovakia
                        flashing bios is mostly the first to do. next is checking all voltages and power line resistances
                        • Stevedb
                          Stevedb
                          • Feb 2018
                          • 624
                          • Belgium
                          Ok because i have no flashtool so i will order one ch341 is good enough?
                          • Stevedb
                            Stevedb
                            • Feb 2018
                            • 624
                            • Belgium
                            hi everybody I got finaly my bios programmer, i will like to flash my hp 450g1 , i bought ch341A programmer black edition , but the chip couldn't be recognice. whe i look to the model is not listed.
                            it is MXic mx25l6473E chip. how can i flash this with ch341a programmer
                            this i hp probook 450g1 wit the 5 times caps lock and numlock blinking problem
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3627
                              • slovakia
                              u cannot have problem flash it. if it is not detected just manually select its series
                              • Stevedb
                                Stevedb
                                • Feb 2018
                                • 624
                                • Belgium
                                Doesn't excist in the list the bios chip
                                • Stevedb
                                  Stevedb
                                  • Feb 2018
                                  • 624
                                  • Belgium
                                  hi i found the solution after a lot of search i found a new version of ch341 program that support the chip. In attachement the new version enjoy it.
                                  but i can not upload it why? it sys invalid file
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    There is no attachment in your post.
                                    Btw I wrote you six hours ago in your other thread what to do.
                                    Become a Badcaps supporter
                                    Thanks to all supporters.
                                    • Stevedb
                                      Stevedb
                                      • Feb 2018
                                      • 624
                                      • Belgium
                                      i know i can not upload it says invalid file but why?
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        i know
                                        So why you perform "a lot of search" then?
                                        Because allowed file types for upload are:
                                        doc
                                        gif
                                        jpe
                                        jpeg
                                        jpg
                                        pdf
                                        png
                                        psd
                                        rar
                                        svg
                                        txt
                                        xls
                                        xlsx
                                        zip
                                        That's why.
                                          HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 07:12 AM
                                          09-07-2024, 06:40 AM
                                          HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                          This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:50 AM
                                          HP ProBook Prenosni računalnik ProBook 445R G6 Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook Prenosni računalnik ProBook 445R G6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Prenosni računalnik ProBook 445R G6 boardview and Prenosni računalnik ProBook 445R G6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-06-2024, 10:51 AM
