Aspire 6530G - no backlight!
  • Dan81
    SNES-powered
    • Oct 2013
    • 1865
    • Romania
    As the title says, I have a 6530G here (that has been recased by myself into a near-pristine 6930G casing) will power on just fine.
    The issue with it is that the backlight will not come on at all. Using a flashlight, I can see the laptop booting into Windows fine, and I do have external (HDMI) output.
    First off, a few specs:
    AMD Turion Ultra ZM-80 2.1GHz
    2GB DDR2 (667 I think)
    ATI Radeon Mobility HD4650 1GB - tested fine on another Acer (model 5520G, w/ MXM slot)
    Hitachi-LG GT30N
    Anyways, I have tested both the display and the inverter, and checked motherboard too.
    Results:
    -display works fine - tested on an Acer Aspire 5536G - backlight lights up.
    -tested inverter - I have the main 19V and ADJUST voltage, but no ENABLE voltage.
    -tested motherboard components responsible for the ENABLE signal - all tested up fine.
    -tested EACH inverter SMD component - all came up fine.
    Anything else I should try? I am at a loss at what else to try.
    Again, the GPU is working fine and so is the LCD itself (Samsung LTN160AT01), and the inverter seems to do its job (as I have read 19v straight from the pin on the inverter PCB) but I don't have any slight hint of the ENABLE signal on the inverter.
    Other useful data:
    MB model: Quanta ZK3 Rev:E
    Inverter model: Sumida IV10117T/C4-E-LF
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Aspire 6530G - no backlight!
    If CN3 is your LVDS Connector check pin 10 1 5 2 voltage
    • Dan81
      SNES-powered
      • Oct 2013
      • 1865
      • Romania
      Yes, CN3 is LVDS.
      Pin 1: 10V
      Pin 2: 0V
      Pin 5: 3.3V
      Pin10: 1.16V
      Main rig:
      Gigabyte B75M-D3H
      16GB DDR3-1600
      Delux MG760 case
      • Techtiger
        • Oct 2014
        • 1601
        • france
        Originally posted by Dan81
        Yes, CN3 is LVDS.
        Pin 1: 10V
        Pin 2: 0V
        Pin 5: 3.3V
        Pin10: 1.16V
        Now check U4 IC all pins expect 2/5 with power and with out power with the help of the multimeter resistance to ground all pins expect 2/5
        • Dan81
          SNES-powered
          • Oct 2013
          • 1865
          • Romania
          Okay, here are the readings, meter set to 2k for 1 and 3, meter set to to 200ohms for 6 and 4.
          No power:
          Pin1: 1.490kOhm
          Pin3: 1.274kOhm
          Pin6: 5Ohm
          Pin4: 5Ohm
          With power applied I get infinite on all pins, and that's with the meter set and tested on each setting - 2k,20k,200k and even 2M.
          I used one of the screws for the left hinge as GND reference.
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
          • Techtiger
            • Oct 2014
            • 1601
            • france
            No power:
            Pin1: 1.490kOhm
            Pin3: 1.274kOhm
            Pin6: 5Ohm
            Pin4: 5Ohm
            Put the meter to 20V and test again Voltage on all pins of U4
            • Dan81
              SNES-powered
              • Oct 2013
              • 1865
              • Romania
              U4
              Pin1:3.21V
              Pin3:3.19V
              Pin6:3.26V
              Pin4:3.28V
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
              • Techtiger
                • Oct 2014
                • 1601
                • france
                Pin 1 is have 3V but the CN3 pin 2 0V check the resistor R22 both sides for Voltage, The screen must be connected to the motherboard when you test
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1865
                  • Romania
                  3.20V on both sides.
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    In Post#3 you have written 0V on pin 2 CN3! So now you have Voltage on pin 2 of CN3
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1865
                      • Romania
                      Yeah, I now figured out why I had 0V first time and have 3.2V. The first time I tried to measure pin2 I had to remove the LVDS cable to have access to it. Dumb move from my part.
                      However, how do I check pin10 now? I successfully found out I have 9V on CN3 pins 1 and 3 (these are the main power to the inverter), 3.20V on pin 2.
                      L.E: I managed to measure pin10 through the pads of unpopulated R175. 1.68V measured.
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                      • Techtiger
                        • Oct 2014
                        • 1601
                        • france
                        Now test Pin 15 BL_ON and Pin5 +3V
                        • Techtiger
                          • Oct 2014
                          • 1601
                          • france
                          Now test Pin 15 BL_ON and Pin5 +3V, For the Main power 10V is for Battery not for the adapter (+19V) leave it for the moment
                          • Dan81
                            SNES-powered
                            • Oct 2013
                            • 1865
                            • Romania
                            Pin5: 3.3V
                            Pin 15: 0.54V
                            Main rig:
                            Gigabyte B75M-D3H
                            16GB DDR3-1600
                            Delux MG760 case
                            • Techtiger
                              • Oct 2014
                              • 1601
                              • france
                              Pin5: 3.3V
                              Pin 15: 0.54V
                              This is your Backlight Control circuit check all voltage , pin 15 Voltage should be 3V-3.3V
                              • Dan81
                                SNES-powered
                                • Oct 2013
                                • 1865
                                • Romania
                                R36: 3.24V
                                R37: 3.24V (both sides)
                                R35: 3.24V only on one side
                                R32: 3.27V only on one side
                                R34: 3.27V on one side, 0.53V on the other
                                Q8: no voltage on any pins
                                Q7: 3.22V on gate
                                Q5: 3.27V on Drain and Source
                                Q4: 0.51V on Drain, nothing on the others
                                D2: 0.51V on one side, 0V on the other
                                Pin 15 still sits at 0.51V.
                                Main rig:
                                Gigabyte B75M-D3H
                                16GB DDR3-1600
                                Delux MG760 case
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1865
                                  • Romania
                                  A photo with the voltages.
                                  At this point I am deciding whether to get another motherboard (a ZK2 this time, at least to put one of my T9400s to a good use) or just rig up a bunch of slim 5v LED strips behind the LCD.
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                  • Techtiger
                                    • Oct 2014
                                    • 1601
                                    • france
                                    Any Other member could help why BL_ON 0.53V?
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3582
                                      • slovakia
                                      no without detailed resistance measuring. i would check that LID signal
                                      post full schematic
                                      please wrote your reading for every pin of that mosfets in red color to picture.
                                      u must have BL# grounded by Q7/gate is high/ so it not grounded by next mosfet/gate is low/ BL_ON signal.
                                      • Dan81
                                        SNES-powered
                                        • Oct 2013
                                        • 1865
                                        • Romania
                                        post full schematic
                                        So if Q7 gate is grounded this enables the BL_ON signal?
                                        Main rig:
                                        Gigabyte B75M-D3H
                                        16GB DDR3-1600
                                        Delux MG760 case
                                          ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 03:36 PM
                                          ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:30 PM
                                          ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ACER Aspire Aspire XC-885 I3408 BE Aspire XC i3-8100 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire XC-885 I3408 BE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-885 I3408 BE boardview and Aspire Aspire XC-885 I3408 BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
