MBP 2017 A1707 left fan get stuck at highest speed
  • dairyu
    • Jan 2019
    • 10
    • Viet Nam
    My friend gave me his MBP after he spilled milk in that. I've checked and cleaned all these but when I assembly it then made MOSFET Q6000 broke. Now it's always been high speed. Already try to solder pin 2 to pin 3 of this MOSFET then I couldn't turn it on. Where do I can find a new one or which ways can get it better? I'm a noob in this job. Thank you so much
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: MBP 2017 A1707 left fan get stuck at highest speed
    DMN32D2LFB4 is on Digikey.
    • CG_Dionysos
      MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
      by CG_Dionysos
      I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
      • Model: A1707
      • 15-inch, Mid 2017
      • 3.1 GHz Core i7
      • 16 GB RAM
      • Radeon Pro 560
      • 1 TB SSD
      • Board number: 820-00928-A
      I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
      Thanks in advance!
      Greetings from Germany...
      09-16-2025, 06:43 AM
    • iZakre
      HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
      by iZakre
      Hello everybody!
      To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
      The thing is that I had installed TeamViewer and could log into the computer...
      02-19-2023, 02:27 PM
    • Arshad alam4659
      A1707 5V STUCK
      by Arshad alam4659
      macbook a1707 820-00928-a no liquid damage 5v stuck i checked some voltage
      PP3V3_G3H=3.4v
      PPVIN_G3H_P3V3G3H=4.7v
      PPDCIN_G3H=5v
      PP1V8_UPC_TB_LDOD=1.79v
      PP3V3_UPC_TB_LDO=3.3v
      PP1V1_UPC_TA_LDO_BMC=1.1v
      PPBUS_G3H=0v no shorting to ground
      what should Icheck next...
      11-14-2024, 07:59 AM
    • sofles
      Macbook a1707 2017 model 820-00928 GPU issue
      by sofles
      Hello there
      I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
      I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
      11-21-2024, 05:25 AM
    • Arshad alam4659
      a1707 5v stuck
      by Arshad alam4659
      i have a motherboard a1707 820-00928-a this board is 5v in stuck and restart again and again all ldo is present ppbus_g3h is 0v no short pp3v3_g3h is 3.3v smc_bc_acok is 3.3v but problem is all voltage is not stable like pp3v3_g3h voltage jumps 3.3v and 2.1v sometime 1.5v and dc also showing 5v then 0v then 2.5v not fixed
      This board was working a day before, the customer came to install the battery, after installing the battery it started working but the next day it is not working
      10-09-2024, 08:56 AM
