Dell 1545 screen backlight on but blank display help me
  • pawankasyap
    • Jul 2017
    • 23
    • india
    Change display cable and screen but same problem plz help me any solution brothers
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Dell 1545 screen backlight on but blank display help me
    how is display on an external monitor?
    • pawankasyap
      • Jul 2017
      • 23
      • india
      External display ok full working
      • pawankasyap
        • Jul 2017
        • 23
        • india
        External display ok
        • pawankasyap
          • Jul 2017
          • 23
          • india
          If I check its display with a 15.6 LCD, the backlit is OK but nothing appears on the screen.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            your mb is with dedicated graphics or Uma??
            • pawankasyap
              • Jul 2017
              • 23
              • india
              Non graphics motherboard
              Roberts MB
              08212-2
              48.4AQ01.021
              • caspian
                • Oct 2015
                • 1589
                • Laptop
                now, the schematics file is required to check out.
                • pawankasyap
                  • Jul 2017
                  • 23
                  • india
                  Help me plz how to check any section
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    schematic is available. You need to check page 13/35.
                    • pawankasyap
                      • Jul 2017
                      • 23
                      • india
                      I do not understand what to check, which point to check help me brother
                      • caspian
                        • Oct 2015
                        • 1589
                        • Laptop
                        CCFL screens are difficult to repair. If you connect another CCFL screen with a different model of Inverter, then the mainboard gets damaged. This scenario happened to me once. that is why I do not like CCFL screens.
                        In general, If the inverter of the old screen gets warm, it is probably defective and should be replaced by the exact same model of inverter.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          @caspian, he is getting backlit as per his post-so inverter is working and it couldnt block data from appearing. So it has nothing to do with inverter. Screen can be a issue if not compatible.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Measure voltage on pin 1-2,4-5,7-8 of lvds connector.Make sure you count the pins correctly.
                            • pawankasyap
                              • Jul 2017
                              • 23
                              • india
                              Thanks i chacked this pin wait
                              • pawankasyap
                                • Jul 2017
                                • 23
                                • india
                                Checked this pin 1-2,4-5,7-8 of lvds connector 0 volt
                                • pawankasyap
                                  • Jul 2017
                                  • 23
                                  • india
                                  No volt
                                  • digitalpc
                                    • Jun 2016
                                    • 305
                                    • .DLL
                                    check connector pins in laptop motherboard you need to have 19v and 3.3v
                                    • pawankasyap
                                      • Jul 2017
                                      • 23
                                      • india
                                      19v and 3.3v present
                                      • pawankasyap
                                        • Jul 2017
                                        • 23
                                        • india
                                        Backlight on but blank display
