voltage regulator modules for laptop
  • NConstantinou
    • May 2017
    • 348
    • Cyprus
    Dear All,
    I heard that there are voltage adjustable modules that can be use for replacing some ic's on laptop if you can not find part.
    does anyone know the exact name or from where to purchase such modules.
    the have input and voltage and variable output.
    thas is all i know.
    thanks
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: voltage regulator modules for laptop
    You can use a buck controller 3V 5V 1.8V ect
    • peste
      • 13199
      • ROMANIA
      Originally posted by NConstantinou
      Dear All,
      thas is all i know.
      thanks
      https://www.google.ro/search?q=dc-dc...Num522LCP4nTeM
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        It depends on the controller you need to replace
        some are controlled via data line (battery), others must still enable with specific times, I don't think it is sufficient to provide only the correct voltages. It is better to look for a replacement chip and adapt it.
          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
          Based on Intersil's Robust Ripple Regulator...
          11-05-2024, 03:24 PM
        • playit
          diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
          by playit
          hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
          and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
          for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
          02-26-2025, 05:39 AM
        • rutgerv
          Acer Swift 3 SF314-42 not powering up
          by rutgerv
          Dear all,
          For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
          The issue with the Acer laptop is the following:
          It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
          08-02-2024, 06:59 AM
          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
          09-06-2024, 09:30 PM
          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 08:47 AM
