Fujitsu Lifebook E546 - No Power
Re: Fujitsu Lifebook E546 - No Power
I replaced the 2nd MOSFET.
No lucky, everytime i put one, the MOSFET starts to have continuity... and seems the 19V needed on circuit don't appear...
I removed it once more and check continuity on MOFSFET pins and theres no continuity even on board and MOSFET... so seems another thing starts to make this issue appears.
I checked the resistor between both 2 first MOSFETS, and have continuity but i have 5.7Ohm this a bad or good sign ?Comment
Hello once more to all, once again I try to fix this motherboard but anything is wrong with it.
I change the Mosfets and read about them, they are N channel mosfets of 30V and some different amperage values.
So I pick up from another boards Mosfets of same values and type N channel and 30v and almost same amperage.
But no lucky... Board still not working and at the first Mosfet at source I have the 19.35v but on drain i get 0.025mV or very low values of voltage... Could someone try to help me please?
I don't belive in 4 different Mosfets I have them all bad... And on 1st of them everytime I change it...Comment
Again remove 1st and 2nd dc in mosfet and then measure resistance on pin1,4 & 5 of both mosfets. Dont apply power after removing them.Comment
OK, i removed the 1st and 2nd DC In MOSFET.
I check the resistence from RED LEAD on ground and BLACK LEAD on each pin you suggest, the values are:
1st MOSFET
Pin 1 (Source) - 12.28 MOhm (No Beep)
Pin 4 (Gate) - 13.26 MOhm (No Beep)
Pin 5 (Drain) - 215.1 kOhm (No Bepp)
2nd MOSFET
1st MOSFET
Pin 1 (Source) - 12.35 MOhm (No Beep)
Pin 4 (Gate) - 13.36 MOhm (No Beep)
Pin 5 (Drain) - 3.575 kOhm (No Bepp)
Remember all this values are measured with red probe on GND and black probe on each pin of motherboard with 2 first DC IN MOSFETs removed like you suggest m.
Hope this help us.
Thnaks once more for your patience.Comment
2nd mosfet, pin5-resistance seems to be very low as it is +19V line. So you do have some faulty component down the line. If you have a dc supply, then apply some voltage on pin5 of 2nd mosfet and check the consumption on your psu. Slowly increasing the voltage observe consumption at 2-3 different voltage levels and post here.Comment
will not make a difference. You need to apply voltage on drain of 2nd mosfet(pin5-6-7-8). Start with 1V/1A and gradually first increase the amp to 5A. If nothing significant start heating, you can gradually increase the voltage. Cmos battery as well backup battery,ac adapter should be removed before applying voltage.Comment
19V - Seems OK
0.011A - is this fine ?
If i try to turn ON, the power LED blinks only but nothing more...Comment
So , your B+ rail is fine. You have some other problems which you need to find out.Comment
This specification for the Fujitsu LIFEBOOK E546 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E546 boardview and E546 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu LIFEBOOK...09-06-2024, 05:54 AM
This specification for the Fujitsu LIFEBOOK E546 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E546 boardview and E546 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu LIFEBOOK...09-06-2024, 05:59 AM
This specification for the Fujitsu LIFEBOOK E546 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E546 boardview and E546 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu LIFEBOOK...09-06-2024, 06:30 AM
This specification for the Fujitsu LIFEBOOK E546 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E546 boardview and E546 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu LIFEBOOK...09-06-2024, 05:46 AM
- Loading...
