Lenovo G510 black screen
  • TVMexicana
    • Mar 2019
    • 32
    Hello all,
    I'm trying to figure out the issue with this Lenovo. Symptom is the computer will power on and the fan will spin but nothing ever really happens. When it turns on I can see that the LCD comes alive except for the backlight, the LCD is not displaying any logos or any bios screen, simply seems to go black as if all the pixels activate. When hooked up to an external monitor through HDMI nothing appears on screen. I can feel that the CPU gets a bit hot as if there is activity. All power rails seem to be okay during my very brief look around for the issue. I have attempted the usual resets such as the holding the power down and etc.
    I looked online and found hints that there may be issue with the hall effect sensor but after a bit of experimenting with that it seems that the hall effect sensor is working fine, at least the sensor itself. Not sure if something in the actual system is malfunctioning but when holding a magnet right to the hall effect sensor the laptop refuses to power on.
    Could this be a bios issue? How would I go about flashing the bios in this state?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo G510 black screen
    Nothing on screen as mb is not posting at all-could be a bios issue. Try flashing it with a known good dump. Dramsrst present on pin 30 of ram slot?? Tried with another processor, ram stick?? Any corrosion on motherboard or liquid spill anywhere?? Just look into these points and everything else seems fine, try flasing bios. Do mention your mb code.
    • u666sa
      • Jan 2014
      • 87
      Whenever I have power on issues and removing battery, resetting RAM, the usual stuff does nothing, and I have to disassemble laptop, I do this first:
      **I unsolder BIOS chip
      **Read BIOS off the chip
      **Write new BIOS off the internet onto the chip
      **If you can't find BIOS on inet, go ahead and write same BIOS back.
      70% of the time it helps and I don't have to do anything else.
      It's one of those plz bro solutions that often solves things.
      You should also have a POST card and at this point at least provide some POST codes.
      • Noursa
        Lenovo Yoga C940-15IRH No primary Screen
        by Noursa
        Hello
        I'am a beginner in electronics repair and i got some trouble to find what's goning on a computer. It is a lenovo yoga C940-15IRH laptop and the screen doesn't work anymore, but that work on an external one
        the screen seams to be hard to unbuild properly so i want to test it by other way
        how can i be sure if the signal is really send to the screen ? i did some check on screen connector on LCD1 got 19v and on MiC1 connector on the other side of the screen (dunno if it's for the screen itself or other thing) got a lot of 3.2v pin
        did u got...
        05-04-2024, 10:00 AM
      • VcemPzd
        Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
        by VcemPzd
        Hello everyone !
        My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
        04-28-2025, 10:14 AM
      • BMCappelletti
        Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
        by BMCappelletti
        Hi everyone.
        Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
        Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
        Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
        02-18-2025, 12:22 PM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • viniciussls
        Notebook won’t turn on after screen replacement - Lenovo Legion Silm 5 16IRH8_LOQ 15IRH8 Compal ILG10 LA-M542P Rev 1.0
        by viniciussls
        Good morning everyone, this is my first post and I apologize in advance if there are any mistakes in the post.
        I have a Lenovo Legion Slim 5 16IRH8_LOQ with the typical issue of stripes on the screen, but I made the mistake of replacing the screen without physically removing the battery, thinking that just pressing the SW2 button would be enough – it wasn't. The board showed consumption, with LED6301 lit up and PU301 getting very hot. I replaced PU301. Now, the board is not working correctly, but it has no consumption, LED6301 stays on, and I haven't found any other signs of a short...
        04-02-2025, 01:40 AM
