Asus x101ch wired problem .
  • mo000
    • Nov 2017
    • 272
    • algeria
    Asus Eee PC X101CH
    board number x101ch rev 3.2
    the problem is the laptop works just after i press on power button twice
    when i put the charger no power led or charging led .
    i found some cafe next the bios chip but i clean it .
  • mo000
    • Nov 2017
    • 272
    • algeria
    Re: Asus x101ch wired problem .
    • mo000
      • Nov 2017
      • 272
      • algeria
      the voltage on power switch and bios chip is 2.1 but after i press the power button the voltage become 2.9 and after i press the power button again the laptop power on .
      • mo000
        • Nov 2017
        • 272
        • algeria
        Any help ?
        • u666sa
          • Jan 2014
          • 70
          • Russia
          I like to start these kind of things with BIOS dump.
          Step 1. Take off chip and write BIOS, see if it solves your problem.
          NO?
          Step 2. Take off CMOS battery and take off laptop battery. When you connect power cord it should automatically turn on. Does it do that?
          NO?
          Step 3. Disconnect dauther board and keyboard, try step 2 again.
          Yes? You have coffee on your power button/dauther board or keyboard.
          NO? Dig deeper.
          On a different note, here is a video for upgrade your RAM. You can put up to 4 GB of RAM onto that poor little thing.
          https://www.youtube.com/watch?v=IR9ez5mdxdw
          Attached is BIOS for X101CH rev 3.2
          • u666sa
            • Jan 2014
            • 70
            • Russia
            Originally posted by mo000
            Asus Eee PC X101CH
            I helped you a little bit, plz help me now. I have same exact motherboard, same revision, battery not charging. Plz measure some voltages for me and report.
            Remove laptop battery and attach power cable before measuring.
            #1. Tell me voltage on pins 1 and 2 from the right.
            #2. Tell me voltage on pin 3 from the left.
            #3. Tell me voltage on this mosfet.
            Your help is highly appreciated and will help me solve my battery charging issues.
            • mo000
              • Nov 2017
              • 272
              • algeria
              voltage on pins 1 and 2 from the right = 18.37
              voltage on pin 3 from the left = 1.86
              voltage on this mosfet = 18.37
              • mo000
                • Nov 2017
                • 272
                • algeria
                1
                NO?
                NO?
                NO? Dig deeper.
                I'm sure it's not bios issue , i flash the bios but nothing change
                step2 the laptop doesn't automatically turn on
                step 3 same thing the laptop doesn't automatically turn on
                when i connect the power cord the led power or charging power must turn on but they still off .
                when i turn on the laptop the charging led blinking .
                • u666sa
                  • Jan 2014
                  • 70
                  • Russia
                  Who you repairing it for? Customer? This does not worth the effort, no service. Yourself? Maybe worth it if if for yourself, provided that you are abel and willing to do memory upgrade. With 1 gig memory this thing is bad in Kali linux under XFCE running a terminal window, picture it running XP.
                  On OU1 find pin 32. See what it does with button pressed. You should have 0 with button pressed.
                  If you do, that means signal from button is coming to the chip. That would mean the chip itself is trash. ICH is not getting PWR_BTN. Try to emitate this signal. Perhaps form your own PWR_BTN and go around OU1. Or replace it, it's about $1 on ali. I would go around controller if I were you..
                  • mo000
                    • Nov 2017
                    • 272
                    • algeria
                    yes for a customer .
                    the voltage on pin 32 is 1.8 after i press pwrbtn the voltage become 3.2 after i press the pwrbtn again and quickly the voltage become 0 .
                    • AtelierRepa
                      ASUS X712JA problem
                      by AtelierRepa
                      I have a problem with the bios, let me explain.
                      With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                      I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                      My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                      The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                      06-15-2024, 04:33 AM
                    • pkslowk
                      Debug Card Error Code and Solution
                      by pkslowk
                      Sr. Motherboard Debug Error Code Solution
                      1 Intel 845 E9 Bios Related Problem
                      2 Intel 845 D4 CPU Socket Related problem
                      3 Intel 845 37 Bios Related Problem
                      4 Intel 845 7C Bios Related Problem
                      5 Intel 945GCPE 34 Bios Related Problem
                      6 Gigabyte 845 2 Ram Related Problem
                      7 IBM Server A6 A7 Ram Mismatch Problem
                      8 Asus 845 29 CPU Related Problem
                      9 Lenovo I946 97 C-Mos Jumper related
                      10 Gigabyte 845 A0 CPU Related Problem
                      11 Asrock G31M-VS D7 Bios Related Problem
                      12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                      01-28-2021, 12:51 PM
                    • Dobrowol
                      Asus GA402RK keyboard and kb backlight problem
                      by Dobrowol
                      Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                      04-28-2025, 04:30 PM
                      ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                      This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                      09-07-2024, 02:50 AM
                      ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                      This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
