identy this ic chip please.
  • kalilinux25
    • Mar 2018
    • 2084
    • ZAMBOANGA SIBUGAY
    MY BOARD IS
    DA0ZQ0MB6E0 REV E
    its PU3 ic
    and its labeled 5Y=2H Q4J
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: identy this ic chip please.
    RT6575CGQW
    • kalilinux25
      • Mar 2018
      • 2084
      • ZAMBOANGA SIBUGAY
      RT6575CGQW
      REALLY GREAT HELP SIR
      I have also 1 question what about this transistor
      its on the POWER BUTTON BOARD
      TRANSISOR
      K92rG
      • rediii
        h???, spurrrn
        • Mar 2018
        • 487
        • somewhere in europe
        RT6575CGQW
        hey mate, how did you know, that this is the right chip? i'm searching for a "translation-tool" because these chips are commonly failing on laptop motherboards? thanks in advance!
        there are other chips that are labelled as 3F=3L XYZ 3T=3L XYZ JJ=DQ XYZ and so on...
          • 20682
          Those are richtek marking codes https://cdn.badcaps-static.com/pdfs/...0c114d947f.pdf
            • 20682
            TRANSISOR
            K92rG
            Post a good photo of the IC with the marking code .
            • rediii
              h???, spurrrn
              • Mar 2018
              • 487
              Originally posted by SMDFlea
              well thats nice. any other suggestions for "marking codes" (i.e. mosfets). thank you very much!
              • kalilinux25
                • Mar 2018
                • 2084
                • ZAMBOANGA SIBUGAY
                [IMG][/IMG]
                • Siddig
                  • Jun 2017
                  • 264
                  • Sudan
                  mabey it can help you
                  • kalilinux25
                    • Mar 2018
                    • 2084
                    • ZAMBOANGA SIBUGAY
                    I cant undetrtant sir it wont show up on online search sir
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                      by SMDFlea
                      Bad...
                      09-02-2021, 04:40 PM
                    • BMCappelletti
                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                      by BMCappelletti
                      Long story short:
                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                      - gave the computer to his son a couple years later
                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                      (seems like the story was not that short)
                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                      01-08-2025, 07:27 PM
                    • Troystain
                      Help EZP2023+ updated chip database for w25q256jveq?
                      by Troystain
                      Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                      I need to add w25q256jveq chip but I do not know what data should I type.
                      I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                      The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                      11-25-2024, 12:53 AM
                    • inck243
                      Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                      by inck243
                      Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                      The BIOS...
                      07-25-2024, 09:17 AM
