Toshiba Satellite S50-B-14Z / No Image
  • nrcslim89
    • Nov 2019
    • 129
    • Portugal
    Hello all, here goes my first thread hope we can deal with this issue together and fix this machine.
    I have here an Toshiba Satellite S50-B-14Z.
    And the issue goes like this:
    - I pull the power button, the machine turns on, but when she must or try to load BIOS screen and start normally,
    - The LCD don't do retroilumonation and it's possible to see with an light pointed to screen an tentative of LCD start,
    - LCD show a totally black screen without any logo of toshiba and in 2 seconds that black screens goes away.
    The machine still working with retro illumination at keyboard, if you click on CAPS or NUMLOCK they show activation light on keyboard.
    So I opened the laptop and checked that BIOS chip has been "touched" by someone without any skills, I remake the solder points and resolded the chip... Seems all fine and continuous mode of multimeter indicates the points are in contact.
    But the issue still here...
    Could anyone help me to discover what I need to check please?
    Thanks for all
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Toshiba Satellite S50-B-14Z / No Image
    So you are trying to say laptop starts but no backlight but the image is DIMM do you get the image on external screen ,did you can connect with HDMI , upload a image and mother board number
    • nrcslim89
      • Nov 2019
      • 129
      • Portugal
      Hey there, thanks for your reply,
      Yes laptop turn on, but don't present any type of image, just for a 2 seconds of a total black image without light and after that 2 seconds lcd seems to get off again like there's no connection.
      On external HDMI port nothing too...
      I will upload the part number of machine and motherboard ID.
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Dissemble the motherboard upload both sides pic , you can do some basic stuff Remove memory remove the bios battery no adapter inserted not even the battery hold down the power button for 10 seconds, Power of the mob and see
        • nrcslim89
          • Nov 2019
          • 129
          • Portugal
          Laptop Info:
          PART NO: PSPQEE-00200KEP
          Motherboard Info:
          A000302600 WFKF03
          DABLIDMB8E0 REV:E
          • nrcslim89
            • Nov 2019
            • 129
            • Portugal
            Ok, i already remove the battery.
            Hold power button for more than 60 sec.
            Theres no removal BIOS battery to get off.
            Already try to change RAM Memory...
            Already tried to only turn on the board with HDMI external LCD, RAM and stll the same.
            • Techtiger
              • Oct 2014
              • 1602
              • france
              For this MB That schematic is available,I have upload a picture of the MB test all Big Gray Coils for Voltage with the help of the multimeter
              • KvnTM
                • May 2018
                • 434
                You mentioned that someone has touched the bios rom. Make sure it is the correct chip and reflash the bios.
                Verify that the chip is W25Q32
                Make a dump of it and post it here
                Flash a new bios bin.
                This all sounds like a bios issue to me..
                • nrcslim89
                  • Nov 2019
                  • 129
                  • Portugal
                  I will verify, but could you please say me what should I verify on multimeter?
                  Just continous mode ?
                  Resistance mode ?
                  • nrcslim89
                    • Nov 2019
                    • 129
                    • Portugal
                    Yes, it seems to be resoldered by another one... i will verify chip ID and post here.
                    But please could you say me how i could reflash BIOS without an programmer ?
                    I am waiting for CH341A programmer at moment...
                    What do you suggest ?
                    • KvnTM
                      • May 2018
                      • 434
                      Do you have an Arduino ?
                      I use one as my primary flashing tool. Works great.
                      You have to use an external programmer. There is no way around since the board is "not working". Either the CH341 or Arduino one.
                      • nrcslim89
                        • Nov 2019
                        • 129
                        • Portugal
                        I only have a raspberry pi 1
                        Maybe couldnt do the job.
                        OK first I will check for coils, there's nothing I can lose, I will wait for Ch341a, Theres no way to flash it with a USB pen with recovery mode??
                        • nrcslim89
                          • Nov 2019
                          • 129
                          • Portugal
                          By the way, what arduino model you suggest?
                          • KvnTM
                            • May 2018
                            • 434
                            Never done it with a raspberry but there's probably a solution for it. Google is your friend.
                            No.
                            I just use a cheap Arduino uno clone which I converted to 3.3v. You can get those for cents from the Chinese markets
                            • Techtiger
                              • Oct 2014
                              • 1602
                              • france
                              Resistance mode ?
                              First in Voltage mode write down all the voltage's then in Resistance mode
                              • nrcslim89
                                • Nov 2019
                                • 129
                                • Portugal
                                Thanks for all support, I will do tomorrow the suggestions, when i have all data I will report here for you.
                                Thanks once more.
                                • nrcslim89
                                  • Nov 2019
                                  • 129
                                  • Portugal
                                  Did you know the value I need to have?
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    Some of the Coil Value
                                    • nrcslim89
                                      • Nov 2019
                                      • 129
                                      • Portugal
                                      Thanks once more,
                                      Now i have been verified the continuity of the coils, most of them are fine, they do the continuity and no short to ground at all.
                                      But, theres one of them thats in short to ground in the two sides of the coil.
                                      Plus... I have two capacitors doing short to ground and they are in the same rail of the coil they come right before of coil, they are:
                                      PC826
                                      PC981
                                      So i test like this, without charger or battery pluged in, i tested the two shorted capacitors in resistance mode with black probe at GND and red probe on Positive side (dot) of capacitor of capacitor and i have this values:
                                      PC981 - 011.4Ohm
                                      PC826 - 011.5Ohm
                                      The coil is next over the capacitors and like i said they are shorted to GND and i assume that is:
                                      PL802 and i have in one side 011.8Ohm (capacitors side) and on another side 07.82kOhm (mosfet side).
                                      Hope you could help me... could you point me an link or attach the schematic please i would like to understand the schematic too.
                                      • KvnTM
                                        • May 2018
                                        • 434
                                        Thanks once more,
                                        PC826
                                        PC981
                                        PC981 - 011.4Ohm
                                        PC826 - 011.5Ohm
                                        If PC826 & PC981 are on vcore rail 11Ohm would be fine. CPUs and GPUs have a very low internal resistance.
                                        Whats the resistance of the inductor itself? Both sides should have about the same resistance to gnd.
                                          Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 05:40 AM
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-12X boardview and Satellite Pro R50-EC-12X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 08:10 PM
