Yoga 700 14-ISK
  • GIFixed
    • Sep 2019
    • 61
    • Denmark
    Yoga 700 14-ISK
    Yoga 700 14-ISK
    Dear all,
    Our customer came in with a lonovo yoga 14-ISK, that "suddenly died".
    No history.
    No water damage.
    It seems the RAM socket was changed: flux residue and not 100% perfectly aligned.
    On some power jumper there are 9V generated from AC-IN:
    PJ201 9V
    PJ204 9V
    PJ802 9V
    PJ803 9V
    PJ301 9V
    PJ801 9V (AT BACKSIDE)
    PJ103: -0.94V (AT BACKSIDE)
    PJ302: 0V
    PJ101: 19.3V
    PJ102: 7.3V -> PF101 (X MARK, OK) -> B+ TERMINAL
    PJ304: 0V
    PJ202: 0V
    PJ205: 0V
    PJ402: 0V
    PJ401:
    Could not find schematic for this board.
    ICs on the board:
    lenovo IT8396VG (BGA)
    PU101: BQ24770
    PU701: NCP81208
    ICs with smd markings:
    PU201: AWV5KC
    PU202: AWW5LB
    PU203: AWS5NA
    PU301: AKUF 926
    U35: R23N
    U101: 5AF2F
    U56: WE 5bG
    Power button missing 3V!
    Any help, thanks
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Yoga 700 14-ISK
    PU201-AWV is your 3V ic and PU202-AWW is your 5V ic. Check whether any of them is shorted. Post clear photo of mb as schematic is unavailable. Btw, what is the mb code??
    • GIFixed
      • Sep 2019
      • 61
      • Denmark
      Re: Yoga 700 14-ISK
      Thank you for your reply.
      I would post photos, but I should recharge the camera first.
      Sorry, I missed the MB code:
      BYG43 NM-A601
      After posting my question, I came across a russian forum mentioning the AWV5KC and AWW5LB from a different laptop. One member answered these two should be:
      SY8286B (3V) and SY8286С (5V).
      I could not find data sheet for SY8286B nor SY8286C, but for SY8286A
      Using that data sheet, I found following for SY8286A:
      https://cdn.badcaps-static.com/pdfs/...3aa9aa7b22.pdf
      Measured for PU202-AWW (5V):
      IN: 9V
      EN: 9V
      VCC: 0V
      BYP: 5V! (where does this 5V come from?)
      LX (coil): 0V (output)!
      Measured for PU201-AWV (3V):
      IN: 9V
      EN: 9V
      VCC: 0V
      BYP: 0V
      All DC-DC converters have 9v as input, but no output.
      Only DC-DC converter that seems (maybe) working is the BQ24770 which produces 7.4V from the 19V AC adapter.
      The 5V rail is 10 ohm to ground.
      I tried to remove PJ202 (5V) jumper and inject 5V. The U101 (5AF2F) gets hot.
      What is the purpose of the U101? Maybe switching betwen 5V USB and 19V USB AC adapter?
      Attached pictures of the motherboard taken with my iPhone.
      Could it be that the EC is always reset?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Re: Yoga 700 14-ISK
        BQ24770 diagram
        https://cdn.badcaps-static.com/pdfs/...680a29ec7a.pdf
        Charger IC in your board is bit different from the earlier days as it has Pmon pins. This drives the B+ rail. I doubt something is wrong here as your rail is 9V. So you need to probe this IC first. Since schematic is not available, i may be wrong and hopefully other members will correct me if i'm wrong.
        • GIFixed
          • Sep 2019
          • 61
          • Denmark
          Re: Yoga 700 14-ISK
          So, I worked more on this motherboard today. Here what I found:
          The PU201 generates 3.3V internally. This 3.3V is connected to the +3VALW_EC thru the zero ohm resistor shown on attached photo. From the other side of the resistor connected to EC and reset circuit for the EC: diode, resistor and capacitor.
          This 3.3V was shorted to ground by the EC. When I removed the 0 ohm resistor, it was back on. But the 3V output of the PU201 was not available.
          If I inject 3V after the resistor, the EC gets hot where I marked with red circle on the EC (IT8396GV).
          Do you agree with me, that the EC is shorted? maybe dead?
          The problem is this EC is BGA, så we have to get it out to check the short.
          Anybody have the pinout and maybe schematic for this EC?
          Any suggestions? Thanks.
          • GIFixed
            • Sep 2019
            • 61
            • Denmark
            Re: Yoga 700 14-ISK
            Reflowed the EC (IT8396VG). Still shorted, mabye 5 ohm to ground.
            Any other boards using this EC?
            • KvnTM
              • May 2018
              • 434
              Re: Yoga 700 14-ISK
              Have you tried resoldering it? Kinda odd that it heats up in the corner. Dont know how large the die is but i belive it won't extend to the edges of that package.
              Maybe someone messed up reballing it? Shorted balls maybe?
              Can't find anything about IT8396VG on google. You sure it is correct?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Re: Yoga 700 14-ISK
                Google shows this ic. just type IT8396VG-192
                • GIFixed
                  • Sep 2019
                  • 61
                  • Denmark
                  Re: Yoga 700 14-ISK
                  I will try removing the EC IC and check underneath.
                  Attached photo of the EC getting worm in a specific area about the "v" in Lonovo word on it.
                  The other photo showing type number.
                  Could not find datasheet for it. And buying over eBay/Aliexpress takes too long time to arrive.
                  Anybody knows if I can buy this chip in Germany or in Europe?
                  • GIFixed
                    • Sep 2019
                    • 61
                    • Denmark
                    Re: Yoga 700 14-ISK
                    Removed the EC and the 4 ohm short is gone.
                    The EC in photo is flipped on its back vertically (up-down). Left-right is correct.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Re: Yoga 700 14-ISK
                      Going by your pic of lifted ec, it doesnt seems reballed. So the ec is actually shorted. As you are aware, needs to be replaced.
                      • KvnTM
                        • May 2018
                        • 434
                        Re: Yoga 700 14-ISK
                        Yup. It's dead.
                        You can either buy the chip from china or get a donor board. There are two from Germany on eBay for 25€ and 30€. Not sure if they have the same fault though.
                        You are better off buying that chip from aliexpress I guess.
                        • GIFixed
                          • Sep 2019
                          • 61
                          • Denmark
                          Re: Yoga 700 14-ISK
                          On pic, red arrow indicates pin shorted to ground.
                          Green line indicates these three pins are on board connected together to the +3VLP (100 mA) LDO output line from PU201.
                          When one of these pins is shorted on the EC itself, the +3VLP is shorted to ground.
                          Click on picture to see it clearly.
                          • KvnTM
                            • May 2018
                            • 434
                            Re: Yoga 700 14-ISK
                            You could inject 3.3v directly into the chip and see if it heats up. Just solder really small wires to it. Finding a gnd pad won't be hard.
                            • GIFixed
                              • Sep 2019
                              • 61
                              • Denmark
                              Re: Yoga 700 14-ISK
                              I didn't have the time to try your suggestion.
                              By the way, we have bought a new IT8396VG from AliExpress. Will arrive in 3 weeks.
                              I will post a result when the new one is tested.
                              • GIFixed
                                • Sep 2019
                                • 61
                                • Denmark
                                Re: Yoga 700 14-ISK
                                UPDATE 19.12.2019:
                                We now received the new EC, changed it and the result:
                                Not shorted anymore, but does not turn on. Only two LEDs on the side of the motherboard/PC are lit. Does not ewspond to holding down power button for 10 seconds.
                                • GIFixed
                                  • Sep 2019
                                  • 61
                                  • Denmark
                                  Re: Yoga 700 14-ISK
                                  Hi again.
                                  Does the IT8396VG come preprogrammed, or I should tell the seller which machine/board, så he can programme it?
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Re: Yoga 700 14-ISK
                                    It doesnt comes pre-programmed unless and otherwise specified on site where you buyed it. I dont know whether this ic requires programming or not but very likely programmable-still not sure.
                                    • Lukosiukas
                                      • Jul 2018
                                      • 106
                                      • Lithuania
                                      Re: Yoga 700 14-ISK
                                      I have same problem, the IT8396VG-192 has short on +3VLP, i was wondering if this chip needs to be programmed or not ? i want to know if this laptop is savable or not.
                                      • Croataa
                                        • Jan 2022
                                        Re: Yoga 700 14-ISK
                                        U101 was geting hot on your Mainboard, do you or someone know what it is exactly, mine is burned and has to be replaced. Cannt find any schematics with the part. Thanks for ur time. ✌️
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:00 AM
                                          Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 6 boardview and X1 Yoga Gen 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
                                          Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
