Weird Issue Lenovo U410 DA0LZ8MB8E0 REV E.
  • aguapanela
    • Mar 2017
    • 19
    • Colombia
    Dear experts ,
    Any advice would be appreciated I am getting this weird behaviour on this motherboard from Lenovo laptop U410 DA0LZ8MB8E0 REV E.
    Lenovo logo shows up then no image at all but board seems to keep it self on but no image.
    I have tried every possible bios bin files for both main bios and EC with no luck.
    When I leave it off for one day the next day it boots up I can get into bios menu but if I switch on and off a couple of times I get the same scenario Lenovo logo then nothing
    I am not quite sure if VCC's voltages are ok since schematic is not very clear about this.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Weird Issue Lenovo U410 DA0LZ8MB8E0 REV E.
    Is backlight on after the Logo when the screen gets blank?
    The next time you get access to the Bios page, look for an option called "Fast Boot" or "Startup Logo". If there is such an option, make it disabled. Then, restart the laptop and look at the messages on the screen (if any).
    • aguapanela
      • Mar 2017
      • 19
      • Colombia
      Hi Caspian, thanks for answering
      Backlight stays on after logo disappears, and I will try disable fast boot and or boot logo if found when I have the chance
      • piernov
        • Jan 2016
        • 4439
        • France
        Confirmed it's not an HDD/ODD problem?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          You can also try by removing sound/lan/card reader chips and then see if it makes any difference.
          • aguapanela
            • Mar 2017
            • 19
            • Colombia
            Yes, confirmed I removed HDD and its additional SSD.
            • aguapanela
              • Mar 2017
              • 19
              • Colombia
              Yes I already did that, thanks for answering
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                was this laptop liquid-damaged or dropped?
                • aguapanela
                  • Mar 2017
                  • 19
                  • Colombia
                  You are right caspian liquid-damaged
                  • caspian
                    • Oct 2015
                    • 1591
                    • Laptop
                    So probably the liquid has damaged a pin of an IC or a ball of the PCH/CPU. Then, you see such a weird behavior.
                    • aguapanela
                      • Mar 2017
                      • 19
                      • Colombia
                      You are probably right caspian Ic's are all fine from what I could check but regarding PCH/CPU is it repairable?
                      • caspian
                        • Oct 2015
                        • 1591
                        • Laptop
                        Does any IC have a dark pin? If so, reflow the IC.
                        Did the liquid approach PCH/CPU location? If so, you can assume a PCH/CPU ball got corroded. Then, try to clean the mainboard using an ultrasonic cleaner. It may resolve the issue. If it did not, a reflowing or reballing may be required.
                        • coasterghost
                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                          by coasterghost
                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                          System Hardware:
                          Processor: AMD Ryzen 7 PRO 5850U
                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                          09-08-2025, 10:46 PM
                        • riko 656
                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                          by riko 656
                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                          Laptop Model:
                          • Model: Lenovo Legion Slim 5 16APH8
                          • GPU: NVIDIA GeForce RTX 4070
                          • Main BIOS chip size: 32MB
                          • VBIOS chip size: 16MB
                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                          What I Have Tried So Far:
                          1. I
                          Today, 05:14 AM
                        • db80
                          Lenovo Ideapad 5 15ARE05 startup issue
                          by db80
                          Hello friends,
                          I've been racking my brain over the past few months on the following issue:
                          I have a Lenovo Ideapad 5 15ARE05 laptop that basically works fine as long it starts up at all.
                          If you shut it down, often you hear the HDD still spinning and the Power LED remains on, it only shuts down if you force it (pressing the power button for like 15 seconds).
                          Then, if you want to Switch it on, nothing happens, only the Power LED lights on, nothing else. If you leave it, then after like 30-60mins it turns on itself.
                          I tried all the common alleged „fixes“...
                          07-06-2024, 05:58 PM
                        • SuperJames
                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                          by SuperJames
                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                          Specs
                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                          Backstory
                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                          10-23-2023, 04:09 PM
                        • totof
                          Lenovo Ideapad 3 15ALC6 motherboard issue
                          by totof
                          I have a Lenovo Ideapad 3-15ALC6 computer that I'm trying to repair.
                          Initially, the computer wouldn't start, and there was no power consumption from the charger. The board itself is reference HS261&HS561&HS761 NM-D521 rev 3.0, where you can find the schematic and board view here: https://www.badcaps.net/forum/troubl...-hs761-nm-d521
                          When I opened it, I noticed three burnt components near...
                          10-26-2025, 10:27 AM
