HP Pavilion 14 chewbacca_14_u_uma battery charging problem
			by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
			Hi all
 We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
 The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
 I have gone around the board with a MM and cant find anything
 Windows shows the battery fine,...
			by piernov1. Some theory
 1.1. Introduction
 Almost every laptop has a charging circuit of some sort, that does a few things:- Manages switching between AC adapter and battery power
- Manages battery charging and generates power rail to charge battery
 There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:- Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
- Narrow VDC (NVDC)
 Texas instrument has a nice overview of these technologies with some more details at https:...
			by kodoxsince i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
 the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
 what i've done:
 - flashing...
			by ShinjuHey All!
 Long time forum member here with a problematic laptop issue!
 I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
 The laptop would not power on with the new battery installed without the power supply being plugged in.
 When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
 TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
- Loading...
