Asus X550C dead
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    Asus X550C dead
    I have problem with this laptop. Is completely dead. Power IC was very hot I replaced it with I mean good replacement from other dead board. uP1589q I replaced it with JC (RT8239B). There are 3.3V and 5V ALW rails now. But DC-IN voltage is not stable. After second mosfet I have weird readings and something clicking. There is no short on 19V power rail. Very weird fault for me. Can someone help me with this, or schematic is availible for this motherboard? I have only boardview.
    Thanks for any answer..
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    Re: Asus X550C dead
    I tried replace first two mosfets after dc-in connector but nothing changed. After second mosfet on current sensor resistor I have weird voltage readings something like 0V-5V-10V-20V my multimeter switch ranges randomly.
    • DeniS182
      • Jun 2014
      • 328
      • Slovakia
      Re: Asus X550C dead
      https://youtu.be/ElkoKmo7dLM
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Re: Asus X550C dead
        check the 2 Fets gate voltage is stable or not PQ8801/2 apply 1V to PR8806 CLR and see is its stable or not
        • DeniS182
          • Jun 2014
          • 328
          • Slovakia
          Re: Asus X550C dead
          gate voltage is not stable. And no short on PR8806
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Re: Asus X550C dead
            Find out Charger IC pin ACDRV Voltage is stable or not and test all components connect to that line
            • DeniS182
              • Jun 2014
              • 328
              • Slovakia
              Re: Asus X550C dead
              I resolder components connected to that line and voltage is now stable. Thanks. But laptop is still dead. Power consumption is 0.01A and after power button is pressed consumption rise up to 0.03A but all LED's stay off.
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Re: Asus X550C dead
                test the voltage PU8802 ACDET ACOK , U3001 pin 14 17 56 57 107 108 85 ,U2801 pin 8 for voltage , PQ9103 PQ9101 PR9104 all pins for +V
                • DeniS182
                  • Jun 2014
                  • 328
                  • Slovakia
                  Re: Asus X550C dead
                  PU8802 - ACDET - 2.6V
                  ACOK - 3V
                  U3001 - 14 - 3.3V
                  17 - 3.3V
                  56 - 0V
                  57 - 0V
                  107 - 0V
                  108 - 0V
                  85 - 0V
                  U2801 pin8 - 3.3V
                  PQ 9103 - not soldered on board
                  PQ9101 - 0V at all pins
                  PR9104 - not soldered on board
                  Do you have schematic please?
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    Re: Asus X550C dead
                    ACOK - 3V
                    U3001 - 14 - 3.3V
                    17 - 3.3V
                    56 - 0V
                    57 - 0V
                    107 - 0V
                    108 - 0V
                    85 - 0V
                    U2801 pin8 - 3.3V
                    no i dont have it, you have to test this voltage when pressing the power button one by one
                    56 - 0V
                    57 - 0V
                    107 - 0V
                    108 - 0V
                    85 - 0V
                    112 ?
                    • DeniS182
                      • Jun 2014
                      • 328
                      • Slovakia
                      Re: Asus X550C dead
                      0V on all these pins when power button is pressed. But on pin 125 I have 3.3V and after power button is pressed it going to zero.
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        Re: Asus X550C dead
                        back up old DUMP and flash bios
                        • DeniS182
                          • Jun 2014
                          • 328
                          • Slovakia
                          Re: Asus X550C dead
                          I desolder bios chip. Try it with other one with dump from this forum. But nothing changed.
                          When I open it with CH341 software it says dump is too big or something like that.. I try to find another dump
                          • DeniS182
                            • Jun 2014
                            • 328
                            • Slovakia
                            Re: Asus X550C dead
                            I flash another dump but still same laptop dead. should I repeat the measurements?
                              • 21279
                              Re: Asus X550C dead
                              Post your bios backup in the Bios requests sub-forum ,and one of the members will fix it .
                              • DeniS182
                                • Jun 2014
                                • 328
                                • Slovakia
                                Re: Asus X550C dead
                                I post my bios backup here: https://www.badcaps.net/forum/showth...142#post920142
                                • Techtiger
                                  • Oct 2014
                                  • 1602
                                  • france
                                  Re: Asus X550C dead
                                  Pin 112 Communication between bios and SIO check again and all pins of BIOS IC for voltage ,check RTCRST RTCVCC R2002for any short
                                  • DeniS182
                                    • Jun 2014
                                    • 328
                                    • Slovakia
                                    Re: Asus X550C dead
                                    R2002 was missing, pads damaged. I fix it with 22k resistor/Original 20K/. PIN 112 - 3.3V. bios pins: 1) 0.3V
                                    2) 1.2V
                                    3) 3.3V
                                    4) 0V
                                    5) 1.3V
                                    6) 1.68V
                                    7and8) 3.3V
                                    • Techtiger
                                      • Oct 2014
                                      • 1602
                                      • france
                                      Re: Asus X550C dead
                                      2) 1.2V
                                      3) 3.3V
                                      4) 0V
                                      5) 1.3V
                                      6) 1.68V
                                      7and8) 3.3V
                                      ok thats great now when you press power BTW pin112 will go high low 3.3V to 0V , and check voltage pin
                                      56 - 0V
                                      57 - 0V
                                      107 - 0V
                                      108 - 0V
                                      85 - 0V
                                      of U3001
                                      • DeniS182
                                        • Jun 2014
                                        • 328
                                        • Slovakia
                                        Re: Asus X550C dead
                                        I mean measured bad pin before because now is 112pin all time zero when is pwr button pressed or not. ANd 56,57,107,108,85 still 0V - when is pwr button pressed or not.
                                        • lukkihapsi
                                          Asus Vivobook X515JA Weird Boot Issue
                                          by lukkihapsi
                                          Asus Vivobook X515JA Laptop
                                          Issue :
                                          Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                          Tried :
                                          Cleaned inside for dust, applied fresh thermal paste. No Change!
                                          Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                          Removed Internal SSD. No Change!
                                          Updated BIOS to latest version. No Change!
                                          Removed battery and pressing power button for 1 minute. No Change!
                                          Weird Part :
                                          Upon turning laptop ON, screen lights up - stays black,
                                          I...
                                          07-07-2025, 12:07 PM
                                        • RotVik
                                          ASUS PRIME B550M-A AC weird behavior
                                          by RotVik
                                          Hello, I need a little help
                                          I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
                                          I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are...
                                          05-01-2025, 04:59 PM
                                          ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-07-2024, 02:50 AM
                                          ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                                          This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
