Inspiron 5570 Charging Issue
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Working on an Inspiron 5570. Initially it had a short to ground which I traced down to a blown ceramic cap (circled in attached photo). Removed the cap et voila, short was gone and the system powered on and charged -- until you unplugged the power adapter and replugged it, at which point the light on the power adapter would slowly fade out and the system would not detect the charger. Pull another cap from a junk board and soldered it back on but it still has the same behavior:
    If the system has no battery it will auto power on when the charger is connected and run fine. If the battery is connected and the power adapter is hooked up it will charge and work perfectly until the first time you unplug and then replug the charger at which point the computer will stay on running off battery power but will no longer detect the charger. The light on the Dell charger will slowly fade out (vs fast off with the initial short) whereas the light on a universal charger I tested with goes to a fast pulse. If the system is powered off and the battery is unplugged it will again charge the battery the first time it is plugged in, but stops detected the charger after the first replug.
    I did see a similar post about a charging problem on this model where the culprit was apparently a resistor:
    https://www.badcaps.net/forum/showthread.php?p=847917
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Inspiron 5570 Charging Issue
    check fet for short on battery output path.
    • mgrharry
      • Sep 2016
      • 211
      • usa
      Thanks for the tip brother! You were connect. Replaced the mosfet shown with one from a donor board, problem solved.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Good job. you posted the pics as well to help others.
        • mgrharry
          • Sep 2016
          • 211
          • usa
          Ran into another of these, same exact problem
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
            DELL Inspiron 5570 Notebook 5000 Specification for Upgrade or Repair
            This specification for the DELL Inspiron 5570 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5570 boardview and 5570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5570...
            09-06-2024, 12:18 PM
