Hi all., I am working on a MacBook Air logic board 820-3437-B. It came in as liquid damage & I revived the logic board. All work & turns on fine & display is perfect, boots up OS well. But there is one problem, if I removed the magesafe 2 jack & put it back in the socket, no green light for a while, & if I leave the magsafe jack connected with no greeen light, automatically after about a min or so the logic board turn on by itself & all voltage are back & logic board works fine. I replaced the clock chip where the corrosion was & I see no broken traces. Since I was not getting any votalge on Fuse F7140 (PPBUS_G3H), I assumed, after a lot of diagnostic that the SMC is acting with the 1-wire circuit. I replaced the SMC but still the same. I replaced know good Cables & the Magsafe/USB/audio board & the J9500 connector too as green corrosion was on that too, but no luck at all. Hope someone can help me out in this. Maybe some Tantalum Cap gone bad??? Thanks in advance for the help.
Apple MacBook Air 820-3437-B
Re: Apple MacBook Air 820-3437-B
A few things:
was the smc from the same model donor board?
did you check around isl, do you get stable acok voltage?
are R53801 & R53802 resitance and volatge ok on bus line?
if they're ok try running asd and look for any errors. -
I'm confused, machine works without PPBUS_G3H? What about PPDCIN and PP3V42_G3H?
Why replace SMC if PPBUS_G3H is missing?
Make sure you are using a good Magsafe2 AC adapter.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
No problem buddy., all tips are great. Ok now I found that the R7006 on PPBUS_G3H line was blown, replaced it but still not luck till now. I am feel I am so close, yet so far. I find resistence reading differences in R7012, R7011 & R7010. I checked with a known good board & the meter shows the difference. I will remove them tomorrow & check., maybe this might be the problem. R7010 & R7011 both show 10K whereas one should be 100K & the other 10K. & R7012 should be 68K, the meter reading is fluctuating between 34K~51K.. Lets see tomorrow where the problem lies. Any more tips will be much appreciated. Thanks once againComment
Ok., I checked the resistance., after removing Q7010, all the resistances readings were prefect. So 100% Q7010 was defective. I replaced it, now turns on fine & PPBUS_G3H line voltages are all ok. Now the fan spins & no self test mode of the logic board, i.e the fan spins then stops & this happens twice & then get the display. Now this does not happen, the fan is spining continously with any pauses & no display, where as first I was getting the display. Any tips now.
& one more help, just received a 820-00165-A logic board, liquid spill on it. I cleaned very well. Turned on & the display fuse F7700 blew. I saw green stuff on the LCD connector J8300. As it was corroded, I replaced both of them. Now the fuse did not flow, the logic board turned on & I get all the voltages, but as soon as I see the backlight the logic board turns off by itself. Any further tips on this.Comment
try a smc reset. Changing Q7010 should not stop the display, unless something else was disturbed by the heatOk., I checked the resistance., after removing Q7010, all the resistances readings were prefect. So 100% Q7010 was defective. I replaced it, now turns on fine & PPBUS_G3H line voltages are all ok. Now the fan spins & no self test mode of the logic board, i.e the fan spins then stops & this happens twice & then get the display. Now this does not happen, the fan is spining continously with any pauses & no display, where as first I was getting the display. Any tips now.Comment
Need to check voltages on backlight boost circuit. The fuse blew for a reason, make sure all pins on the LVDS connector are soldered properly and there is continuity.& one more help, just received a 820-00165-A logic board, liquid spill on it. I cleaned very well. Turned on & the display fuse F7700 blew. I saw green stuff on the LCD connector J8300. As it was corroded, I replaced both of them. Now the fuse did not flow, the logic board turned on & I get all the voltages, but as soon as I see the backlight the logic board turns off by itself. Any further tips on this.
U7701 often gets liquid damaged, check the balls under a microscope for corrosion.Comment
820-3437 is supposed to spin/stop 3 times after losing battery power.
820-00165: Please open another thread for a different issue.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Ok., as soon as I install the SSD, the problem starts again. Even with known good SSD, same!! & with the SDD all works fine, display is ok & get all known voltages. Anyone got a problem like this?? Do you think BIOS is the issue, but battery charges well to 100%Comment
Apple MacBook Pro 13" A1706 Logic Board 820-00923 Schematic & Board View...
Channel: Schematics and Boardviews
by GuestHello all!
Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it.... -
Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
I'm new to soldering but the only feasible way to fix this issue is to do something myself.
MY QUESTION:
I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)... -
by samstownHello,
This special tool from Apple is used to recover data from Macbook A1706. I've been using it for a while but it stops working. When connecting Thunderbolt 3 between the tool and working Macbook, Macbook should prompt "new device detected, allow or not"... but it doesn't.
Has anyone ever experience this ? It's not a cabling or power supply issue, some IC have stopped working but not sure which one. Probably the one that manager thunderbolt 3
Claude... -
by ledbylightHi all!
This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more
, and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
11-04-2024, 06:36 PM - Loading...
