Dell Latitude E4310 slow boot
+ More Options
Posts
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Latest BIOS A15
    Fastboot: Minimal
    Boot Device Options: Modular Bay HDD (1st) & USB Storage Device (2nd)
    Something wrong with primary SATA which has previously corrupted an SSD, so has SSD in caddy occupying optical drive bay
    Takes >10 seconds from power on or restart to show Dell splash screen
    Can I do anything to improve this? - is it timing out detecting no device on primary SATA, or ??
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Dell Latitude E4310 slow boot
    That is possible. Even an empty Sata controller can make extra delay. but it is not common to happen. An ME issue is more probable. you can follow the instructions in the following post:
    https://www.badcaps.net/forum/showpo...23&postcount=5
    what have you found on the Sata that you think it damaged the SSD?
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Thanks Caspian
      Started off thinking about https://www.badcaps.net/forum/showpo...83&postcount=8
      But same issue - what would I use to read or write the BIOS?
      Flashrom produces a severe warning, and Dell BIOS updater is all-in-one locked up
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        you need to desolder the Bios IC and reprogram it using a flash/EEPROM programmer.
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          Thanks again Caspian
          I might have to just live with slow boot in that case
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            I bought Latitude with issue disclosed that it couldn't run Windows from primary SATA
            Didn't examine hardware - just tried a known working Patriot Blast SSD
            Afterwards SSD seemed to have lost its firmware - as I recall symptom, SSD's controller was communicating with computer (different one) but wasn't aware it had any storage
            I raised case with Patriot, requesting software which could low-level format the SSD, but after some back-and-forth they issued RMA instead
            • caspian
              • Oct 2015
              • 1589
              • Laptop
              Does the Sata HDD boot fine in this laptop now?
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                I haven't tried a HDD on primary SATA
                Corrupted SSD had to be returned to Patriot in Taiwan
                Different SSD works fine in a caddy using the optical drive bay
                • caspian
                  • Oct 2015
                  • 1589
                  • Laptop
                  it is possible that some pins on the SSD connector are shorted or have bad voltages. So, do not connect another SSD to that connector.
