Imac a1418 no power 820-00143-02
  • mobajer
    • Feb 2017
    • 10
    • Lithuania
    Hello, i have imac 2015 21.5', customer says that sometimes still was able to turn it on. Openeed lcd, when power lead plugged, green light on ligic board shines.
    On power button there are 3.4v, when pressed becomes 0v, when released again 3.4v.
    Board looks as clean as new. What would you advice to check next? Is there any schematic?
    Mother number: 820-00143-02
    Thank you
  • mobajer
    • Feb 2017
    • 10
    • Lithuania
    Re: Imac a1418 no power 820-00143-02
    Has anybody tried reball cpu?
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • ryogadan78
      iMac A1418 - No LED, no power after overvoltage on Ethernet port
      by ryogadan78
      Hi guys, I need your help again.
      I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
      When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
      06-10-2025, 03:49 AM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
      03-31-2024, 02:12 PM
