Hp15 DA0U99MB6C0 REV :C tipping off , bios flashed but problem passist pls help me out
Hp15 DA0U99MB6C0 REV :C tripping off
Re: Hp15 DA0U99MB6C0 REV :C tripping off
It would help if you would list what tests and measurements you`ve taken so far... -
The schematic https://www.badcaps.net/forum/showthread.php?t=76389
check for short on AD_IDComment
by kalilinux25Hi it has forgotten the password of the laptop .
bios been attached
HP Notebook - 15-f100dx...-
Channel: BIOS Requests ONLY!
08-18-2021, 03:06 AM -
by Loli PopuHello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
by lpraderiHello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
In some cases to use LVDS screen PCB use converter IC RTD2132/6
Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
...11-25-2023, 09:31 AM -
by letsfixthisHey,
I have been trying since 2 days to get this working.
The Acer VN7-791 had the 30 Minutes shutdown issue.
Therefore I desoldered the BIOS, cleaned the ME Region (with the Win-Raid guide) and Flashed the Version again.
It seems to have solved the reboot issues.
But unfortunately now I cannot turn off the computer anymore. It just reboots when I do it via Windows 10 or the Power Button. Only thing working is hard Reset via long press of the Power Button.
I tried to install an older Version of Mangement Engine... -
by kadi144good day
i seek a HP15-e073sf core I3 BIOS
the motherboard is DAR62CMB6A0 REV:A UMA
the problem coming no display
thanks-
- Loading...
