Asus X555LD rev 3.3 black screen
  • Tafita
    • Sep 2018
    • Madagascar
    Hey there,
    I have a problem with an Asus x555LD rev 3.3
    Power LED on, battery is charging, but black screen, no fan and no HDD LED.
    I tried to :
    - connect with an external monitor
    - reprogram bios
    but no change
    Can you give me any advice of how to fix it?
    Thanks in advance.
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Asus X555LD rev 3.3 black screen
    Originally posted by Tafita
    Hey there,
    I tried to :
    - reprogram bios
    but no change
    Thanks in advance.
    Yes we can help you but need more info of the MOB in you mother board there are Big Gray colis test the voltage of them try with another RAM how did you reprogram bios ?
    • Tafita
      • Sep 2018
      • Madagascar
      Thanks for your reply.
      I don't have schematic and I can't test voltages. I just noticed that BIOS voltage is 2.5V (pin 8) and I don't know if it is normal.
      I tried to replace external RAM but nothing change.
      I removed BIOS from the motherboard and reprogrammed with CH341A.
      • Techtiger
        • Oct 2014
        • 1601
        • france
        here is the boardview file the voltage for bios pin 8 is less it should be 3+V the pin 8 is connected with 3 Resistors a one Cap & Diode you have test them try to change the BIOS battery with help of the boardview try to find out the voltage of all PL coils big Gary ones you have one near the SOC processor
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I think VS voltages are not proper. You need to find out the ALW to VS mosfets and check voltage on all pins. Fan is not spinning -that does mean absence of +5V VS or it is dropping low. Had the exact same symtoms on dell N5050 nad was solves by replacing VS mosfets.
          • HTR-Informatique
            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
            by HTR-Informatique
            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
            I also changed the screen because the PC fell and the screen was broken.
            I changed the battery with a new and original battery.
            I also had corrosion/oxidation on the...
            02-09-2025, 06:51 AM
          • Technodoc
            ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
            by Technodoc
            Asus laptop G614JZ-N3012W Rog Strix with i7
            Mainboard G634J-PMV-VGT
            6050A3441302-MB-A01
            2023-02-10
            Power button works okay....power light goes on
            Red "bottom" leds go on
            Charging led works
            Fans do not spin, capslock key does nothing, screen stays black
            I would like to program the bios again, to rule out a corrupted bios.
            However I run into a size error
            The bios chip is a Winbond 25R256JVEN
            Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
            02-24-2025, 04:46 AM
          • andrestecno
            ASUS X201e - The screen does not turn on and remains black
            by andrestecno
            I'm dealing with an intermittent problem and can't find a solution. Sometimes my notebook starts up and everything works fine. However, after I turn it off and try to turn it on again, the motherboard starts, but the screen stays black. It seems like the notebook freezes and a green LED with a light bulb icon stays on.
            If anyone has the service manual or any suggestions on how to fix this issue, I would greatly appreciate it.
            Thanks in advance!
            07-18-2024, 07:14 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Nyquistnoise
            Asus Vivobook Pro 16X OLED No boot/Black screen
            by Nyquistnoise
            Hoping to get some directions on a current repair of an Asus Vivobook Pro 16X. The laptop powers but shows no other signs of life, and appears to have all typical supplies according to boardview files (attached). Both CPU, GPU & PCH get sensibly warm & thermal camera reveals no obvious shorts. The only supply that makes me slightly wary is +1V8_AON_PLLVDD, as this measures 1V2. I believe this may be normal, however?
            Pressing the power button gives you a lit keyboard & power/battery lights, but that's about it. No display (internal or external via HDMI)...
            02-02-2025, 07:10 AM
