Looking for an smd part
  • memoslar
    • Apr 2015
    • 122
    • Greece
    Hi . I have an ssd kingspec 16gb. It works with 5v but accidentally supplied with 12v. I am looking for a smd part which marking code is LDACC. Can you help me find this one to replace them. They are three burned.
    • 21948
    Re: Looking for an smd part
    It could be a silergy SY8088
    • R_J
      • 9607
      I agree, SY8088, LD, A=year,C=week,C=lot code
      • memoslar
        • Apr 2015
        • 122
        • Greece
        oh my god. thank you very much..
        • edugimeno
          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
          by edugimeno
          Hi There!
          I'm trying to help my friend who owns a restaurant be just bought.
          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
          It's stuck using, I guess, the 2 sided tape that comes with the strip
          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
          09-05-2024, 09:34 AM
        • G-Sting
          iPad Pro A1876 SHORT Part Identify Help Needed
          by G-Sting
          So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
          So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
          i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
          SO My main concern is what part should i order what should i search the name for ?
          on Ipad...
          05-15-2025, 09:30 AM
        • tech_guru
          Cannot find PS5 IC (marking F2=8D) part number
          by tech_guru
          Hello everyone.
          Is there any chance somebody can find the part number of this chip or equivalent, in the attached photo?
          It is from PS5 EDM-020 board, in the front usb section, near F3502.
          It must be a Richtek ic, vqfn32 package style.
          Thank you in advance....
          05-27-2024, 01:37 AM
        • Yanleb
          Panasonic part number in service manuals
          by Yanleb
          In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
          This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
          For an example, look at the attached PDF.
          Do you have a way to cross reference the Panasonic part number with the actual part number?
          Thanks....
          07-03-2023, 08:16 PM
        • FreakyMex
          Trouble to identify part (Lunii screen) for replacement
          by FreakyMex
          Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
          I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
          02-17-2025, 01:16 AM
