acer +vcc_core and No CPU heat
  • kokono
    • Jun 2018
    • 203
    i working in this board, DA0ZRTMB6D0 REV D
    i checked all voltage, is ok except GFX voltage.
    but i dont have video output, i have a good question,
    i checked VCC_Core , is 1.7v but cpu is cold.
    What does it mean? cpu is dead ?
    1 - 0V
    2 - 0V
    3 - 0V
    4 - 1,7V
    5 - 1.06V
    6 - 1,3V
    7 - 5V
    8 - 3,3V
    9 - 1,5V
    10 - 2,7V
    • 20745
    Re: acer +vcc_core and No CPU heat
    Theres another thread with the same problem,maybe it`ll help . https://www.badcaps.net/forum/showthread.php?t=74562
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      1 & 2 is for graphics power and 3 is perhaps PCH Power. One thing is for sure, your graphics chip is not initialised and hence no gfx core(as its discrete mb). You can try removing coils 1 & 2 and see if gfx core comes up.
      • piernov
        • Jan 2016
        • 4435
        • France
        Tried to flash the BIOS?
        • kokono
          • Jun 2018
          • 203
          But this topic finished without result
          NO, 1,2 and 3 all is for GFX
          number 3 is 1.5v_GFX
          If you have a good bios, please send it
            • 20745
            https://www.badcaps.net/forum/showthread.php?t=65552
            • kokono
              • Jun 2018
              • 203
              Thx but dont work
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                " NO, 1,2 and 3 all is for GFX "-What do you mean by that?? i already told you coil 1 & 2 is for gfx power and you need to find out why graphics not getting power without which you wont have gfx core enabled on a discrete platform.
                • kokono
                  • Jun 2018
                  • 203
                  i attached power states, i have all voltage until +VCCIN( cpu core). next level ist +3v_GFX . i checked DGPU_PWR_EN . is null
                  So i think is normal that dont have GFX core voltage.
                  PCH send DGPU_PWR_EN signal . So I have to draw a conclusion, that PCH dont work ???
                  in addition, i read in another forum that ,in first dont need GFX start
                  In this disc you have 2 graphics, only one will be powered -none +VGPU_CORE in this state is correct.
                  Voltage + 1.5V_GFX appears only during the POST procedure
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    If BIOS doesn't POST, graphics voltage won't come up. Wrote that in the other thread as well.
                    • kokono
                      • Jun 2018
                      • 203
                      Anyone say something to measure?
                      • Techtiger
                        • Oct 2014
                        • 1601
                        • france
                        Yes PCH is not responding check SIO pin 78 PCh PWROK ? SYS RESET ? EC PWROK ?
                        • kokono
                          • Jun 2018
                          • 203
                          pin 78=3.3v
                          EC PWROK =3.3v
                          SYS RESET is strange
                          please check attach
                          • Techtiger
                            • Oct 2014
                            • 1601
                            • france
                            pin 78=3.3v
                            what is the resestence to GND on coil 1 2 3 with no voltage did you try to remove one PAD of coil 1 2 to see if voltage is coming back (mcplslg123) have ask you ! may be a BIOS with out Oscilloscope it's hard to say
                            • kokono
                              • Jun 2018
                              • 203
                              1,2 ist about 13ohm
                              and 3 is 9 ohm
                              i dont try because before these voltage ,we should have +3V_GFX ,But is null
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                i asked you to remove coil 1 &2 'coz of this very reason that you wont have +3v gfx. It might be so 'coz of bad graphics chip also. Thats why asked you to avoid graphics power circuit by removing those 2 coils and see if anything changes. have seen , that on many-many discrete mobo's. Btw, its your choice.
                                • kokono
                                  • Jun 2018
                                  • 203
                                  Thx for suggestion,i tested another things
                                  i pullup "DGPU_PWR_EN" with R620 ,and now i have 1.5v in PL10(Coil 3) and about 0.9v in PL6 and PL7(Coil 1&2) , and Graphic chip Warmed up .So i think chip graphic and all voltage for chip is ok and working.
                                  But this job is for PCH , maybe i have a short smd resistor or PCH integrated dont answer
                                  it is strange, Coil4 have 1.7 volt but cpu not warm(very low)
                                  • kokono
                                    • Jun 2018
                                    • 203
                                    Also i checked SYS_PWROK is 3v
                                    So EC_PWROK and IMVP_PWRGD_3V is 3v
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Yes, that proves graphics chip is fine.
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        I still suspect bios issue. Have you tried this bios
                                        https://www.laboneinside.com/acer-as...ev-d-bios-bin/
                                        This bios is tested ok.
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Swift SF314-43-R46R + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF314-43-R46R + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-43-R46R + Pack Gold Acer 14'' boardview and SF314-43-R46R + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 03:10 AM
